AWECore 8.C.2 API Document
Errors.h
Go to the documentation of this file.
1 /*******************************************************************************
2 *
3 * Audio Framework
4 * ---------------
5 *
6 ********************************************************************************
7 * Errors.h
8 ********************************************************************************
9 *
10 * Description: AudioWeaver Framework Error Codes
11 *
12 * Copyright: (c) 2007-2021 DSP Concepts, Inc. All rights reserved.
13 * 3235 Kifer Road
14 * Santa Clara, CA 95054
15 *
16 *******************************************************************************/
17
25 #ifndef _ERRORS_H
26 #define _ERRORS_H
27
28
29
31 #define E_SUCCESS (0)
32
34 #define E_HEAP_INDEX_RANGE (-1)
35
37 #define E_MALLOC_SIZE_TOO_BIG (-2)
38
40 #define E_SCRATCH_ALLOC_SIZE_TOO_BIG (-3)
41
43 #define E_CONSTRUCTOR_ARGUMENT_COUNT (-4)
44
46 #define E_CLASS_INDEX_RANGE (-5)
47
49 #define E_CLASS_NOT_FOUND (-6)
50
52 #define E_MODULE_ALREADY_OWNED (-7)
53
55 #define E_ASSIGN_ADDRESS_OUT_OF_RANGE (-8)
56
58 #define E_MODULE_NOT_WIRE (-9)
59
61 #define E_INPUTS_MUST_MATCH_OUTPUTS (-10)
62
64 #define E_INPUTS_MUST_BE_SAME_PINTYPE (-11)
65
67 #define E_MUST_HAVE_INPUTS (-12)
68
70 #define E_MUST_HAVE_OUTPUTS (-13)
71
73 #define E_INPUTS_MUST_MATCH_CORRESPONDING_OUTPUTS (-14)
74
76 #define E_NOT_MODULE (-15)
77
79 #define E_INPUT_OUTPUT_COUNT (-16)
80
82 #define E_PARAMETER_ERROR (-17)
83
85 #define E_NO_MORE_OBJECTS (-18)
86
88 #define E_NOT_OBJECT_POINTER (-19)
89
91 #define E_NOT_INPUT_PIN (-20)
92
94 #define E_IOPIN_IN_USE (-21)
95
97 #define E_PIN_TYPES_NOT_COMPATIBLE (-22)
98
100 #define E_PIN_SIZES_NOT_COMPATIBLE (-23)
101
103 #define E_NOT_OUTPUT_PIN (-24)
104
106 #define E_NO_MORE_IOPINS (-25)
107
109 #define E_NO_LAYOUTS (-26)
110
112 #define E_MUST_HAVE_ONE_OUTPUT (-27)
113
115 #define E_OUTPUT_MUST_BE_SINGLE_VALUE (-28)
116
118 #define E_INCOMPATIBLE_BLOCK_SIZES (-29)
119
121 #define E_WIRE_INDEX_RANGE (-30)
122
124 #define E_NO_EVENT_HANDLER (-31)
125
127 #define E_AUDIO_ALREADY_STARTED (-32)
128
130 #define E_AUDIO_ALREADY_STOPPED (-33)
131
133 #define E_COMMUNICATIONS_ERROR (-34)
134
136 #define E_SALT_OBJECT_NOTFOUND (-35)
137
139 #define E_SALT_FIELD_RANGE (-36)
140
142 #define E_SALT_STATE_RANGE (-37)
143
145 #define E_NOT_IMPLEMENTED_IN_RS232 (-38)
146
148 #define E_BADPACKET (-39)
149
151 #define E_BADFILE (-40)
152
154 #define E_FILENAMELENGTH (-41)
155
157 #define E_CANTCREATE (-42)
158
160 #define E_CANTOPEN (-43)
161
163 #define E_NOSUCHFILE (-44)
164
166 #define E_IOERROR (-45)
167
169 #define E_FIND_FIRST_FILE_NOT_CALLED (-46)
170
172 #define E_NO_MORE_FILES (-47)
173
175 #define E_BAD_FILENAME (-48)
176
178 #define E_FILE_ALREADY_OPEN (-49)
179
181 #define E_FILE_NOT_FOUND (-50)
182
184 #define E_ILLEGAL_FILE_ATTRIBUTE (-51)
185
187 #define E_FILE_ALREADY_EXISTS (-52)
188
190 #define E_NO_OPEN_FILE (-53)
191
193 #define E_OUT_OF_SPACE (-54)
194
196 #define E_END_OF_FILE (-55)
197
199 #define E_ERROR_READING_FLASH_MEMORY (-56)
200
202 #define E_ERROR_WRITING_FLASH_MEMORY (-57)
203
205 #define E_ERROR_ERASING_FLASH_MEMORY (-58)
206
208 #define E_COMMAND_NOT_IMPLEMENTED (-59)
209
211 #define E_INTERNAL_MODULE_ALLOCATION_FAILURE (-60)
212
214 #define E_HARDWARE_FAILURE (-61)
215
217 #define E_REGISTER_INVALID (-62)
218
220 #define E_REGISTER_BUSY (-63)
221
223 #define E_REGISTER_NOT_IMPLEMENTED (-64)
224
226 #define E_REGISTER_READ_ONLY (-65)
227
229 #define E_NO_HEAP_MEMORY (-66)
230
232 #define E_ARGUMENT_ERROR (-67)
233
235 #define E_DUPLICATE_ID (-68)
236
238 #define E_ID_OUT_OF_RANGE (-69)
239
241 #define E_READ_ONLY (-70)
242
244 #define E_BAD_HEAP_POINTER (-71)
245
247 #define E_HEAPS_ALREADY_INITIALIZED (-72)
248
250 #define E_HEAPS_NOT_INITIALIZED (-73)
251
253 #define E_EXCEPTION (-74)
254
256 #define E_MESSAGE_LENGTH_TOO_LONG (-75)
257
259 #define E_CRC_ERROR (-76)
260
262 #define E_UNKNOWN_MESSAGE (-77)
263
265 #define E_MSG_TIMEOUT (-78)
266
268 #define E_OBJECT_ID_NOT_FOUND (-79)
269
271 #define E_PIN_ID_NOT_FOUND (-80)
272
274 #define E_NOT_OBJECT (-81)
275
277 #define E_BAD_MEMBER_INDEX (-82)
278
280 #define E_CLASS_NOT_SUPPORTED (-83)
281
283 #define E_PUMP_OVERRUN (-84)
284
286 #define E_NOT_V7 (-85)
287
289 #define E_NO_FRAMEWORK (-86)
290
292 #define E_NO_CORE (-87)
293
295 #define E_IOPIN_TOO_MANY (-88)
296
298 #define E_WIRE_ALREADY_BOUND (-89)
299
301 #define E_WIRES_NOT_SPECIFIED (-90)
302
304 #define E_NOT_CREATED (-91)
305
307 #define E_ALREADY_CREATED (-92)
308
310 #define E_AUDIO_NOT_STARTED (-93)
311
313 #define E_LINKEDLIST_CORRUPT (-94)
314
316 #define E_MODULE_NOT_INITIALIZED (-95)
317
319 #define E_INVALID_FILE (-96)
320
322 #define E_NO_MORE_ROUTES (-97)
323
325 #define E_PUMP_NO_LAYOUTS (-98)
326
328 #define E_NULL_PACKET_BUFFER_POINTER (-99)
329
331 #define E_NULL_REPLY_BUFFER_POINTER (-100)
332
334 #define E_ZERO_PACKET_BUFFER_LENGTH (-101)
335
337 #define E_CALLBACK_NOT_REALTIME (-102)
338
340 #define E_PRIORITY_NOT_HI_ENOUGH (-103)
341
343 #define E_SCHEDULER_PERMISSION_DENIED (-104)
344
346 #define E_INVALID_PORTNO (-105)
347
349 #define E_CANNOT_CREATE_THREAD (-106)
350
352 #define E_UNEXPECTED_EOF (-107)
353
355 #define E_OFF_ARRAY_END (-108)
356
358 #define E_NO_MORE_THREADS (-109)
359
361 #define E_SOCKET_OPEN_FAIL (-110)
362
363
364
365 #ifdef DEFINE_ERROR_STRINGS
366
367 static const char *s_error_strings[] =
368 {
369  "success", //#define E_SUCCESS (0)
370  "no such heap", //#define E_HEAP_INDEX_RANGE (-1)
371  "heap allocation request too large", //#define E_MALLOC_SIZE_TOO_BIG (-2)
372  "scratch allocation request too large", //#define E_SCRATCH_ALLOC_SIZE_TOO_BIG (-3)
373  "constructor argument count wrong", //#define E_CONSTRUCTOR_ARGUMENT_COUNT (-4)
374  "no such class index", //#define E_CLASS_INDEX_RANGE (-5)
375  "class name not found", //#define E_CLASS_NOT_FOUND (-6)
376  "module already owned by layout", //#define E_MODULE_ALREADY_OWNED (-7)
377  "address out of range", //#define E_ASSIGN_ADDRESS_OUT_OF_RANGE (-8)
378  "module used, wire expected", //#define E_MODULE_NOT_WIRE (-9)
379  "input must match outputs", //#define E_INPUTS_MUST_MATCH_OUTPUTS (-10)
380  "input pintypes don't match", //#define E_INPUTS_MUST_BE_SAME_PINTYPE (-11)
381  "input(s) must be specified", //#define E_MUST_HAVE_INPUTS (-12)
382  "output(s) must be specified", //#define E_MUST_HAVE_OUTPUTS (-13)
383  "inputs must match corresponding outputs", //#define E_INPUTS_MUST_MATCH_CORRESPONDING_OUTPUTS (-14)
384  "not a module", //#define E_NOT_MODULE (-15)
385  "input/output count wrong", //#define E_INPUT_OUTPUT_COUNT (-16)
386  "Parameter error", //#define E_PARAMETER_ERROR (-17)
387  "no more objects found", //#define E_NO_MORE_OBJECTS (-18)
388  "pointer value is invalid", //#define E_NOT_OBJECT_POINTER (-19)
389  "not an input pin", //#define E_NOT_INPUT_PIN (-20)
390  "I/O pin is in use", //#define E_IOPIN_IN_USE (-21)
391  "pin types not compatible", //#define E_PIN_TYPES_NOT_COMPATIBLE (-22)
392  "pin sizes not compatible", //#define E_PIN_SIZES_NOT_COMPATIBLE (-23)
393  "not an output pin", //#define E_NOT_OUTPUT_PIN (-24)
394  "no more pins found", //#define E_NO_MORE_IOPINS (-25)
395  "no layout(s) to pump", //#define E_NO_LAYOUTS (-26)
396  "must have one output", //#define E_MUST_HAVE_ONE_OUTPUT (-27)
397  "output must be single value", //#define E_OUTPUT_MUST_BE_SINGLE_VALUE (-28)
398  "incompatible block sizes", //#define E_INCOMPATIBLE_BLOCK_SIZES (-29)
399  "wire index out of range", //#define E_WIRE_INDEX_RANGE (-30)
400  "module has no event handler", //#define E_NO_EVENT_HANDLER (-31)
401  "audio already started", //#define E_AUDIO_ALREADY_STARTED (-32)
402  "audio already stopped", //#define E_AUDIO_ALREADY_STOPPED (-33)
403  "communications error", //#define E_COMMUNICATIONS_ERROR (-34)
404  "SALT object not found", //#define E_SALT_OBJECT_NOTFOUND (-35)
405  "SALT field range error", //#define E_SALT_FIELD_RANGE (-36)
406  "SALT state range error", //#define E_SALT_STATE_RANGE (-37)
407  "not implemented", //#define E_NOT_IMPLEMENTED_IN_RS232 (-38)
408  "bad packet received", //#define E_BADPACKET (-39)
409  "invalid filename", //#define E_BADFILE (-40)
410  "filename too long", //#define E_FILENAMELENGTH (-41)
411  "file create failed", //#define E_CANTCREATE (-42)
412  "file open failed", //#define E_CANTOPEN (-43)
413  "no such file", //#define E_NOSUCHFILE (-44)
414  "file I/O error", //#define E_IOERROR (-45)
415  "FindNext called without FindFirst", //#define E_FIND_FIRST_FILE_NOT_CALLED (-46)
416  "no more files found", //#define E_NO_MORE_FILES (-47)
417  "bad filename", //#define E_BAD_FILENAME (-48)
418  "file already open", //#define E_FILE_ALREADY_OPEN (-49)
419  "no such file", //#define E_FILE_NOT_FOUND (-50)
420  "illegal file attribute", //#define E_ILLEGAL_FILE_ATTRIBUTE (-51)
421  "file already exists", //#define E_FILE_ALREADY_EXISTS (-52)
422  "no open file", //#define E_NO_OPEN_FILE (-53)
423  "file system full", //#define E_OUT_OF_SPACE (-54)
424  "end of file", //#define E_END_OF_FILE (-55)
425  "FLASH read error", //#define E_ERROR_READING_FLASH_MEMORY (-56)
426  "FLASH write error", //#define E_ERROR_WRITING_FLASH_MEMORY (-57)
427  "FLASH erase error", //#define E_ERROR_ERASING_FLASH_MEMORY (-58)
428  "no such command", //#define E_COMMAND_NOT_IMPLEMENTED (-59)
429  "internal module allocation error", //#define E_INTERNAL_MODULE_ALLOCATION_FAILURE (-60)
430  "hardware failure", //#define E_HARDWARE_FAILURE (-61)
431  "register invalid", //#define E_REGISTER_INVALID (-62)
432  "register busy", //#define E_REGISTER_BUSY (-63)
433  "register not implemented", //#define E_REGISTER_NOT_IMPLEMENTED (-64)
434  "register read only", //#define E_REGISTER_READ_ONLY (-65)
435  "create heap failed", //#define E_NO_HEAP_MEMORY (-66)
436  "invalid argument", //#define E_ARGUMENT_ERROR (-67)
437  "duplicate ID", //#define E_DUPLICATE_ID (-68)
438  "ID out of range", //#define E_ID_OUT_OF_RANGE (-69)
439  "read only", //#define E_READ_ONLY (-70)
440  "bad heap pointer", //#define E_BAD_HEAP_POINTER (-71)
441  "heaps already initialized. same memory location?", //#define E_HEAPS_ALREADY_INITIALIZED (-72)
442  "heaps not initialized", //#define E_HEAPS_NOT_INITIALIZED (-73)
443  "framework exception", //#define E_EXCEPTION (-74)
444  "message too long", //#define E_MESSAGE_LENGTH_TOO_LONG (-75)
445  "CRC error", //#define E_CRC_ERROR (-76)
446  "unimplemented or invalid command ID", //#define E_UNKNOWN_MESSAGE (-77)
447  "message timed out", //#define E_MSG_TIMEOUT (-78)
448  "object ID not found", //#define E_OBJECT_ID_NOT_FOUND (-79)
449  "no such pin", //#define E_PIN_ID_NOT_FOUND (-80)
450  "not an object", //#define E_NOT_OBJECT (-81)
451  "bad member index", //#define E_BAD_MEMBER_INDEX (-82)
452  "not supported", //#define E_CLASS_NOT_SUPPORTED )-83)
453  "audio overrun", //#define E_PUMP_OVERRUN (-84)
454  "not a V7 target", //#define E_NOT_V7 (-85)
455  "no framework", //#define E_NO_FRAMEWORK (-86)
456  "no such core", //#define E_NO_CORE (-87)
457  "too many bound wires", //#define E_IOPIN_TOO_MANY (-88)
458  "wire already bound", //#define E_WIRE_ALREADY_BOUND (-89)
459  "wires must be specified", //#define E_WIRES_NOT_SPECIFIED (-90)
460  "instance not created", //#define E_NOT_CREATED (-91)
461  "instance already created", //#define E_ALREADY_CREATED (-92)
462  "audio not started", //#define E_AUDIO_NOT_STARTED (-93)
463  "linked list corrupted", //#define E_LINKEDLIST_CORRUPT (-94)
464  "module not initialized", //#define E_MODULE_NOT_INITIALIZED (-95)
465  "invalid file content", //#define E_INVALID_FILE (-96)
466  "no more routes", //#define E_NO_MORE_ROUTES (-97)
467  "pump initiated with no layout", //#define E_PUMP_NO_LAYOUTS (-98)
468  "packet buffer Pointer not initialized", //#define E_NULL_PACKET_BUFFER_POINTER (-99)
469  "reply buffer Pointer not initialized", //#define E_NULL_REPLY_BUFFER_POINTER (-100)
470  "packet buffer length is 0", //#define E_ZERO_PACKET_BUFFER_LENGTH (-101)
471  "audiocallback not at a rt priority", //#define E_CALLBACK_NOT_REALTIME (-102)
472  "audiocallback not at high enough rt priority", //#define E_PRIORITY_NOT_HI_ENOUGH (-103)
473  "cant get/set sched priority. permission denied", //#define E_SCHEDULER_PERMISSION_DENIED (-104)
474  "invalid portno. must be 15002-15098 and even", //#define E_INVALID_PORTNO (-105)
475  "Couldn't create thread or process with OS constructs", //#define E_CANNOT_CREATE_THREAD (-106)
476  "Loading from array reported EOF early", //#define E_UNEXPECTED_EOF (-107)
477  "off buffer pool end", //#define E_OFF_ARRAY_END (-108)
478  "no more threads", //#define E_NO_MORE_THREADS (-109)
479  "AWECoreOS integrated socket failed to open", //#define E_SOCKET_OPEN_FAIL (-110)
480 };
481 #endif // DEFINE_ERROR_STRINGS
482
483 #endif // _ERRORS_H
484
