AWECore 8.C.2 API Document
Go to the documentation of this file.
24 #ifndef PROXYIDS_H_INCLUDED
25 #define PROXYIDS_H_INCLUDED
193 PFID_EnableAddressTranslation = 55,
361 PFID_GetInstanceTable = 127,
Function ID for GetCores().
Definition: ProxyIDs.h:374
Function ID for awe_fwFetchValue() as float.
Definition: ProxyIDs.h:293
Function ID for awe_fwGetHeapCount().
Definition: ProxyIDs.h:77
Command ID for FlashContent Read() awe_fwSetCall().
Definition: ProxyIDs.h:197
Function ID for awe_fwGetNextObject().
Definition: ProxyIDs.h:119
Function ID for awe_GetCall() as float followed by awe_fwFetchValue().
Definition: ProxyIDs.h:308
Function ID for awe_GetCall() followed by awe_fwFetchValues().
Definition: ProxyIDs.h:232
Allocate framework heaps.
Definition: ProxyIDs.h:211
Function ID for awe_fwSetPointer().
Definition: ProxyIDs.h:237
tProxyFuncID
Enumeration of Proxy function IDs.
Function ID for StopAudio().
Definition: ProxyIDs.h:131
Get module status by handle.
Definition: ProxyIDs.h:359
Function ID for awe_GetFileSystemInfo().
Definition: ProxyIDs.h:173
Set value(s) by handle.
Definition: ProxyIDs.h:356
Function ID for awe_DeleteFile().
Definition: ProxyIDs.h:161
Function ID for awe_fwGetCall().
Definition: ProxyIDs.h:54
Function ID for awe_fwAddModuleToLayout().
Definition: ProxyIDs.h:188
Function ID for awe_fwGetModuleState().
Definition: ProxyIDs.h:107
Function ID for awe_fwGetClassType().
Definition: ProxyIDs.h:59
Function ID for awe_FileSystemReset().
Definition: ProxyIDs.h:179
Function ID for report first core.
Definition: ProxyIDs.h:281
Stop audio without callback.
Definition: ProxyIDs.h:344
Function ID for awe_fwGetQueryFlashEraseComplete().
Definition: ProxyIDs.h:263
Function ID for awe_WriteFile().
Definition: ProxyIDs.h:155
Function ID for awe_fwSetValue() as float.
Definition: ProxyIDs.h:299
Function ID for awe_GetFirstFile().
Definition: ProxyIDs.h:143
Function ID for awe_fwGetBaudRates().
Definition: ProxyIDs.h:266
Function ID for awe_fwGetCIModuleCount().
Definition: ProxyIDs.h:86
Function ID for reboot().
Definition: ProxyIDs.h:275
Function ID for awe_CloseFile().
Definition: ProxyIDs.h:158
Function ID for awe_fwSetValue() followed by awe_fwSetCall.
Definition: ProxyIDs.h:314
Function ID for awe_fwGetHeapSize().
Definition: ProxyIDs.h:80
Generate a comment on command line.
Definition: ProxyIDs.h:339
Function ID for awe_fwGetSizeofInt().
Definition: ProxyIDs.h:140
Special for target integrity bchecks.
Definition: ProxyIDs.h:333
Definition: ProxyIDs.h:336
Function ID for awe_fwSetValue() awe_fwSetCall().
Definition: ProxyIDs.h:191
Function ID for awe_OpenFile().
Definition: ProxyIDs.h:149
Function ID for awe_fwSUpdateLookupTable().
Definition: ProxyIDs.h:245
Set module status by handle.
Definition: ProxyIDs.h:362
Function ID for awe_fwSetBaudRate().
Definition: ProxyIDs.h:269
Definition: ProxyIDs.h:296
Function ID for ClassLayout_Constructor().
Definition: ProxyIDs.h:95
Definition: ProxyIDs.h:305
Function ID for awe_fwGetPinType().
Definition: ProxyIDs.h:62
Function ID for destroy without stop.
Definition: ProxyIDs.h:330
Function ID for awe_fwSetValue().
Definition: ProxyIDs.h:317
Function ID for ClassLayout_Process().
Definition: ProxyIDs.h:113
Undefined ID - zero.
Definition: ProxyIDs.h:48
Definition: ProxyIDs.h:74
Get the first IPC route.
Definition: ProxyIDs.h:347
Definition: ProxyIDs.h:182
Function ID for awe_fwGetWireType().
Definition: ProxyIDs.h:254
Function ID for awe_fwDestroyAll().
Definition: ProxyIDs.h:278
Function ID for awe_fwFetchValue().
Definition: ProxyIDs.h:71
Function ID for StartAudio().
Definition: ProxyIDs.h:128
Set value(s) by handle and mask.
Definition: ProxyIDs.h:368
Command ID for update firmware() awe_fwSetCall().
Definition: ProxyIDs.h:194
Function ID for awe_fwGetNextIO().
Definition: ProxyIDs.h:125
Get extended target info.
Definition: ProxyIDs.h:371
Function ID for awe_fwSetValues() as float followed by awe_fwSetCall.
Definition: ProxyIDs.h:302
Function ID for BindIOToWire().
Definition: ProxyIDs.h:68
Function ID for awe_fwCreateWireInBufferPool().
Definition: ProxyIDs.h:382
Set an object's ID.
Definition: ProxyIDs.h:220
Get value(s) by handle and mask.
Definition: ProxyIDs.h:365
Function ID for awe_fwPumpModule().
Definition: ProxyIDs.h:110
Function ID for awe_fwGetProfileValues().
Definition: ProxyIDs.h:176
Command to forcefully corrupt DMA and lock DSP.
Definition: ProxyIDs.h:272
Function ID for ClassWire_Constructor().
Definition: ProxyIDs.h:65
Function ID for awe_ReadFile().
Definition: ProxyIDs.h:152
Function ID for awe_fwSetModuleState().
Definition: ProxyIDs.h:104
Function ID for awe_fwcreateLookupTable().
Definition: ProxyIDs.h:242
Definition: ProxyIDs.h:290
Single message write-pump-read combo.
Definition: ProxyIDs.h:217
Function ID for awe_GetCall() followed by awe_fwFetchValue().
Definition: ProxyIDs.h:229
Function ID for awe_fwPumpLayout().
Definition: ProxyIDs.h:248
Definition: ProxyIDs.h:134
Function ID for awe_fwSetCall().
Definition: ProxyIDs.h:51
Definition: ProxyIDs.h:287
Definition: ProxyIDs.h:200
Function ID for awe_fwSetInstanceID().
Definition: ProxyIDs.h:257
Function ID for awe_fwSetValues() followed by awe_fwSetCall.
Definition: ProxyIDs.h:226
Function ID for awe_fwGetFlashEraseTime().
Definition: ProxyIDs.h:260
Function ID for awe_GetTargetInfo().
Definition: ProxyIDs.h:170
Function ID for awe_fwGetFirstIO().
Definition: ProxyIDs.h:122
Function ID for ClassModule_Constructor().
Definition: ProxyIDs.h:92
Function ID for awe_fwDestroy().
Definition: ProxyIDs.h:83
Function ID for awe_fwGetWire().
Definition: ProxyIDs.h:101
Get the next IPC route.
Definition: ProxyIDs.h:350
Function ID for awe_fwDerefPointer().
Definition: ProxyIDs.h:251
Definition: ProxyIDs.h:223
Function ID for awe_fwGetObjectByID().
Definition: ProxyIDs.h:185
Start audio without callback.
Definition: ProxyIDs.h:341
Function ID for awe_GetNextFile().
Definition: ProxyIDs.h:146
Function ID for awe_fwSetWire().
Definition: ProxyIDs.h:98
Function ID for awe_fwGetFirstObject().
Definition: ProxyIDs.h:116
Destroy framework heaps.
Definition: ProxyIDs.h:214
Function ID for awe_fwGetCIModuleInfo().
Definition: ProxyIDs.h:89
Definition: ProxyIDs.h:320
Function ID for awe_ExecuteFile().
Definition: ProxyIDs.h:164
Definition: ProxyIDs.h:137
Function ID for awe_EraseFlash().
Definition: ProxyIDs.h:167
Function ID for report next core.
Definition: ProxyIDs.h:284
Definition: ProxyIDs.h:311
Get value(s) by handle.
Definition: ProxyIDs.h:353
Function ID for awe_fwCreateWireBufferPool().
Definition: ProxyIDs.h:379
Definition: ProxyIDs.h:325
