AWECore 8.C.10 API Document
This document is meant to be a "Quick-Start" on how to integrate AWE Core. Advanced concepts are left out. Before reading this document, please see the Theory Of Operation document.
The AWE Core™ is a hardware-independent, reconfigurable audio-processing engine. The AWE Core includes over 400 audio-processing Modules, from mixers and filters to compressors and FFTs, that can be combined to easily create complex signal processing flows. The AWE Core operates by passing audio through a user-defined sequence of these Modules, as directed by Configuration-data at run-time.
Term | Definition |
API | Application Interface |
AWE Instance | The main AWE Core object |
Tuning Interface | The interface by which commands/replies are transferred |
Layout | Audio Weaver signal processing flow |
Sub-Layout | Clock-divided section of a layout |
AWB | Audio Weaver Binary File |
AWD | Audio Weaver Design File |
AWE | Audio Weaver |
AWS | Audio Weaver Script File |
BSP | Board Support Package |
IPC | Inter Process Communication |
RTOS | Realtime operating system |
RT | Real-time |
This document will go over the basics of integrating the AWE Core. It also includes a Doxygen-generated map of all the available API Functions, Macros, Data Structures, etc. AWECore.h API Doc.
For a brief view of the API, see the 'AWECore_cheatsheet.pdf' in this package.
For a more detailed description of the Tuning Protocol and the various transport methods, please see the Tuning Protocol document here.
Here are the basic steps to integrate AWE Core.
A number of variables must be defined before configuring/initializing the AWE Instance.
//declare and initialize to zeros AWEInstance g_AWEInstance = {0};
Later, in the initialization section, it will become clear that there are several fields of the AWEInstance structure that must be configured before it can be used to process audio data.
static IOPinDescriptor s_InputPin; static IOPinDescriptor s_OutputPin;
//The list of class objects is defined in ModuleList.h const void* g_module_descriptor_table[] = { LISTOFCLASSOBJECTS};
UINT32 g_FastHeapA[FAST_HEAP_A_SIZE]; UINT32 g_FastHeapB[FAST_HEAP_B_SIZE]; UINT32 g_SlowHeap[SLOW_HEAP_SIZE];where FAST_HEAP_A_SIZE, FAST_HEAP_B_SIZE, and SLOW_HEAP_SIZE are chosen appropriately for the system. See the Optimization section for more details.
#define PACKET_BUFFER_SIZE 264 UINT32 AWE_Packet_Buffer[PACKET_BUFFER_SIZE];
UINT32 AWE_Packet_Buffer_Reply[PACKET_BUFFER_SIZE];
Note: The standard packet size is 264. If a different packet size is needed, please contact DSPC Engineering.
Now that the required variables have been declared, the AWE Instance will be configured by assigning its members and pointers.
g_AWEInstance.instanceId = 0;
g_AWEInstance.pInputPin = &s_InputPin; g_AWEInstance.pOutputPin = &s_OutputPin;
g_AWEInstance.pPacketBuffer = AWE_Packet_Buffer;
g_AWEInstance.pReplyBuffer = AWE_Packet_Buffer_Reply;
#define PACKET_BUFFER_SIZE 264 g_AWEInstance.packetBufferSize = PACKET_BUFFER_SIZE;
g_AWEInstance.pModuleDescriptorTable = g_module_descriptor_table;
UINT32 module_descriptor_table_size = sizeof(g_module_descriptor_table) / sizeof(g_module_descriptor_table[0]); g_AWEInstance.numModules = module_descriptor_table_size;
g_AWEInstance.numThreads = 2; //dual threaded, supports two blocksizes
g_AWEInstance.sampleRate = 48000.0f;
#define AWE_BLOCK_SIZE 32 g_AWEInstance.fundamentalBlockSize = AWE_BLOCK_SIZE;
g_AWEInstance.pFlashFileSystem = 0;
g_AWEInstance.fastHeapASize = FAST_HEAP_A_SIZE; g_AWEInstance.fastHeapBSize = FAST_HEAP_B_SIZE; g_AWEInstance.slowHeapSize = SLOW_HEAP_SIZE;
g_AWEInstance.pFastHeapA = g_FastHeapA; g_AWEInstance.pFastHeapB = g_FastHeapB; g_AWEInstance.pSlowHeap = g_SlowHeap;
g_AWEInstance.coreSpeed = 10e6f; g_AWEInstance.profileSpeed = 10e6f;
g_AWEInstance.pName = “mytarget”;
//this example represents a date g_AWEInstance.userVersion = (UINT32) 06212019;
The next step is to first initialize the IO Pins followed by initializing the AWE Instance using specific API functions.
Simply call the awe_initPin() function and pass it the input pin, the desired channel count (determined by audio HW), and an optional pin name. See API doc for data type details.
#define TWO_CHANNELS 2 int ret = awe_initPin(g_InputPin, TWO_CHANNELS, NULL);
The code above would initialize the input pin with 2 channels, and the default name.
Initializing the output pin is the same as the input pin, but the output pin is passed in.
#define SIX_CHANNELS 6 int ret = awe_initPin(s_OutputPin, SIX_CHANNELS, "outpin");
The code above would initialize the output pin with 6 channels with the name "outpin".
NOTE: multiple IO pins not supported. There can only be one input pin and one output pin. All API's that take the argument "pinIdx" will always pass in 0.
Next, initialize the AWE Instance by calling the awe_init() function. This must happen as the last initialization step. If awe_init() is called before the AWE Instance structure is configured or before the IO pins are initialized, the initialization will fail.
int ret = awe_init(&g_AWEInstance);
The code above will initialize the AWE Instance.
The next step is to implement a tuning interface – arguably the most important component of a successful AWE Core integration as it provides essential debugging capabilities. The tuning interface communicates commands/replies to and from the AWE Instance. For example, these commands can instantiate a layout, or set and query the value of a module parameter.
Different platforms will support different transport protocols for the tuning interface. AWE Server supports USB, TCP/IP (sockets), RS232, SPI, etc. Helper code is available to aid in the development of these different transport layers on the target. It is the responsibility of the integrator to enable the transport protocol for the tuning commands to be passed to and from the platform.
Here are the basic steps for setting up and using a tuning interface with AWE Server.
AWE_Packet_Buffer
and then call awe_packetProcess(&g_AWEInstance)
on the instance. Remember that this packet buffer has been registered with the AWE Instance, which is why the awe_packetProcess(&g_AWEInstance)
function does not need to take an argument to the packet buffer.AWEInstance.pReplyBuffer
. If the same buffer is used for both send and reply, the reply message will overwrite the original command.int sizeOfPacket = 264; readPacket(&AWE_Packet_Buffer, sizeOfPacket) awe_packetProcess(&g_AWEInstance) writePacket(&AWE_Packet_Buffer_Reply, sizeOfPacket)
The next step is to integrate real-time audio. AWE Core aside, real-time audio can be a tricky topic. Before attempting to integrate real-time audio into an AWE Core system, please ensure that the integrator has a basic understanding of digital audio and real-time audio processing. Here are some helpful links.
http://www.rossbencina.com/code
Giulio Moro - Assessing the stability of audio code for real time low latency embedded processing
1 << N
, for N=0:numThreads-1, to determine which layouts are ready to be pumped. Based on the system's capabilities, each layout should be pumped at it's own interrupt level/thread priority. See the Multi-Rate section for more information.The data type of the input and output audio data is determined by the audio hardware. Typically, digital audio is represented as fixed point data in 16, 24, or 32 bit depth. The audio sample formats supported by AWE Core's awe_audioImportSamples() and awe_audioExportSamples() functions, as defined in SampleType in StandardDefs.h, are:
Internally, all inputs and outputs to Audio Weaver layouts are of type Sample32bit, also referred to as fract32 within a layout. This is done to guarantee portability of any signal processing layout to any target system, regardless of the hardware's native audio data type. The awe_audioImportSamples() and awe_audioExportSamples() functions will convert to and from the Sample32bit data as needed based on the integrator's supplied _SampleType argument. If the target's native audio sample formatting is not one of those listed above, then the integrator will have to manually convert the data to one of the supported types before using the import and export functions.
Since some common target systems natively support floating point audio, helper functions are provided to convert between float<-->fract32 in AWECoreUtils.c, which is provided in the AWE Core package. Add AWECoreUtils.c to the build project to access the sample-by-sample conversion functions float_to_fract32 and fract32_to_float. See the API in doc AWECoreUtils.h for more info.
The AWE Core allows audio to be processed at multiple block rates. For example, consider a system with two processing paths: one that processes time-domain data in blocks of 32 samples and another that processes frequency-domain data in blocks of 64 samples but at 1/2 the rate of the time-domain path. Such a system is shown in the figure below. It uses BufferUp and BufferDown modules to connect the different block size domains. These modules effectively partition the layout into 2 sub-layouts operating at different block rates.
The two paths are executed at different rates and AWE Core’s awe_audioGetPumpMask() API call provides a mechanism to determine when the processing for each path should be initiated. Consider the following pseudocode:
layoutMask= awe_audioGetPumpMask(&g_AWEInstance); if (layoutMask & 0x1) raise(AWEProcess_HiPrio); if (layoutMask & 0x2) raise(AWEProcess_LowPrio); AWEProcess_HiPrio() { awe_audioPump(g_AWEInstance, 0); // small block size path } AWEProcess_LowPrio() { awe_audioPump(g_AWEInstance, 1); // large block size path }
This code tests which sub-layouts have accumulated enough data to execute. The layoutMask variable contains a 1 in each bit position corresponding to sub-layout that is ready to execute. For example, if layouts 0 and 1 are ready to execute,
layoutMask = 0x00000003
Lower numbered sub-layouts correspond to smaller block sizes. In the pseudo-code, a signal is raised for each sub-layout that is ready to be pumped.
Real-time constraints dictate that if the 64 sample sub-layout is executed in the same context as the 32 sample sub-layout, both will need to complete processing before the next block of 32 samples arrives or real-time will be broken. This imposes an unnecessarily strict constraint on the 64 sample sub-layout – its processing need only be completed before the next block of 64 samples is accumulated. Thus, its processing time can, in principle, be spread over 2 of the 32 sample block times without breaking real-time. In practice, this is achieved by executing the two sub-layouts in separate contexts. The sub-layout with the shorter block size should have higher priority so that it can preempt the processing of the sub-layout with the longer block size. In this way, the real time constraints of each sub-layout can be accommodated. The following figure shows the timing for this example:
There are certain AWE modules that need to perform time consuming calculations, for example when the cutoff frequency of a Second Order Filter module is changed, the filter coefficients need to be recalculated. Performing these calculations in the audio processing context can cause it to overrun. To address this issue, certain modules defer those calculations until the firmware calls awe_deferredSetCall()
An integrator can check for any required deferred processing using the return value of awe_audioPump(), which will return TRUE
if any deferred processing is pending. If deferred processing is needed, then call awe_deferredSetCall() at a priority that is lower than the audio processing. awe_deferredSetCall() performs deferred processing for a single module, and returns TRUE
if there is more deferred processing that is pending. Thus it should be called repeatedly until it returns FALSE
//g_bDeferredProcessingRequired is returned by awe_audioPump() if (g_bDeferredProcessingRequired || bMoreProcessingRequired) { g_bDeferredProcessingRequired = FALSE; bMoreProcessingRequired = awe_deferredSetCall(&g_AWEInstance); }
At this point, the integrator should be able to load a layout from Audio Weaver Designer and run it on the target via the Tuning Interface. Once a Layout in Designer has been completed, it is easy to switch to stand-alone operation. Simply ask Audio Weaver to "Generate Target Files", and the Layout's configuration-data will be generated as a C array to be compiled into the system.
From the viewpoint of AWE Core, the signal processing layout is described by a data array of binary Audio Weaver commands. This command array is generated by Audio Weaver Designer using the Tools/Generate Target Files menu item and enabling the [BaseName]_initAWB checkbox. The layout is loaded into an AWE Core instance by making a call to awe_loadAWBfromArray with the command array, its size in 32-bit words, and the AWEInstance as arguments. If an error occurs during loading, then the offset of the offending AWB command is returned to the pPos argument.
INT32 err = awe_loadAWBfromArray (pAWE, pCommands,arraySize, &nErrOffset ); if (err) { // report the error printf(“error code %u due to command at position %u\n”, err, nErrOffset); // handle the error ... }
awe_loadAWBfromArray() will load the entire array of commands and process them locally on the AWE Instance. If an array of commands needs to be loaded on a remote instance, it can be loaded command by command with the awe_getNextAWBCmd() helper function in AWECoreUtils.h. Each command is parsed so that they can be routed to the remote instance.
All priority and interrupt issues are managed outside of the AWE Core by the firmware integrator since the AWE Core has no knowledge of the supporting processing environment it is being integrated into. The following processing context may be implemented using interrupt handlers or using OS threads/tasks. The main requirement is that the processing context is implemented at different preemptible priority levels.
A basic Audio Weaver platform has a minimum of five priority levels of processing. From highest priority to lowest priority:
These three actions must be atomic to avoid the possibility of race conditions due to concurrent access of resources.
A control interface lets the system interact with modules in the running layout directly from the firmware. To access the layout from the API, use Designer to generate a control-interface header file for the layout. Then, use the following API calls define the functionality of the control interface:
Get/set a value of a module: awe_ctrlGetValue() and awe_ctrlSetValue()
INT32 awe_ctrlGetValue(const AWEInstance *pAWE, UINT32 handle, void *value, INT32 arrayOffset, UINT32 length) INT32 awe_ctrlSetValue(const AWEInstance *pAWE, UINT32 handle, const void *value, INT32 arrayOffset, UINT32 length)
Get/Set the status of a module (bypassed, active, inactive, muted): awe_ctrlSetStatus() and awe_ctrlGetStatus()
INT32 awe_ctrlSetStatus(const AWEInstance *pAWE, UINT32 handle, UINT32 status) INT32 awe_ctrlGetStatus(const AWEInstance *pAWE, UINT32 handle, UINT32 *status)
Check if a module exists, and if so return its ClassID: awe_ctrlGetModuleClass()
The following functions provide finer grained control over how module variables get set and are for advanced users: awe_ctrlSetValueMask() and awe_ctrlGetValueMask()
INT32 awe_ctrlSetValueMask(const AWEInstance *pAWE, UINT32 handle, const void *value, INT32 arrayOffset, UINT32 length, UINT32 mask) INT32 awe_ctrlGetValueMask(const AWEInstance *pAWE, UINT32 handle, void *value, INT32 arrayOffset, UINT32 length, UINT32 mask)
To access a module and control it via the Control Interface,
handle, length
arguments will all be defined in the [BaseName]_ControlInterface.h file that was generated. See the API doc for details about the control functions arguments/return values.See the following example.
// Does the current AWE model have a SinkInt module with this control object ID? if (awe_ctrlGetModuleClass(&g_AWEInstance, AWE_SinkInt1_value_HANDLE, &classID) == OBJECT_FOUND) { // Check that module assigned this object ID is of module class SinkInt if (classID == AWE_SinkInt1_classID) { // SinkInt module (value is an array) awe_ctrlGetValue(&g_AWEInstance, AWE_SinkInt1_value_HANDLE, &nValue, 0, 1); } }
The AWE Core can be optimized for a system for heap space and for image size.
In a typical workflow, the integrator would decide on heap size/placement for development and finally optimized for production.
To decide on heap size/placement for board bring-up, set all three heaps to some small number of 1K word blocks say (1024 * 5). When the BSP is fully developed inspect the memory map to determine how much free space is available in the memory sections that have been assigned to the heaps. Then adjust the heap space to use as much of this memory as is practical. A typical assignment of heap might be to assign processor “tightly coupled memory” to fast heap A, processor RAM to fast heap B, and off-chip SDRAM to the slow heap.
Audio Weaver Designer can also generate the absolute smallest heap sizes needed for a specific layout via Tools->Generate Target Files and selecting [BaseName]_HeapSize.h. This can greatly reduce the memory footprint and aid in optimizing an AWE Core integration.
The ModuleList.h file that is delivered with AWE Core contains a large set of modules. This is convenient during development to provide a large selection of modules with which to design layouts. To optimize for a specific layout at production time, Audio Weaver Designer can generate a ModuleList.h with only the modules used by that layout using Tools->Generate Target Files->[BaseName]_ModuleList.h. Since most modern linkers will only link those modules referenced, this will significantly reduce the image size.
AWE Core target systems can contain multiple AWE Instances. This is useful on a platform with multiple cores when a system needs to do signal processing on each core.
Before setting up a multi instance tuning interface, we recommend implementing a single instance tuning interface. This will solidify the theory of operations and allow for easier understanding of the multi instance model.
AWE Core packets always contain a prefixed address called an “instanceID”. On a single instance system, this instanceID is always 0. However, when developing a multi instance system, commands can be addressed to different instanceID’s.
When using Designer, the instanceID of an AWE command is determined by which instance is selected in the dropdown window of Designer.
It is important to note that there can only be one tuning interface between Server and the system. That single tuning interface will receive the packets for all instances and the BSP integrator must route them to the correct instance.
Integrating a multi-instance AWE Core system can be broken into the following basic steps. This assumes that the integrator is able to implement a single instance tuning interface.
//the following instance table represents a two-instance system. UINT32 numInstances = 2; UINT32 instanceIDs[numInstances] = { 0, 16 };
if (opcode == PFID_GetInstanceTable) { GenerateInstanceTableReply(AWE_Packet_Buffer_Reply, numInstances, instanceIDs); writePacketToServer(AWE_Packet_Buffer_Reply); }
The following pseudocode example is for a chip with two signal processing cores with the first core providing the tuning interface.
TuningInterface() { AWE_Packet_Buffer = receivePacketFromServer(); if (PACKET_OPCODE(AWE_PACKET_BUFFER)) == PFID_GetInstanceTable) { *AWE_Packet_Buffer = *GenerateInstanceTableReply(AWE_Packet_Buffer, numInstances, instanceIDs); writePacketToServer(AWE_Packet_Buffer); } else if (PACKET_INSTANCEID(AWE_Packet_Buffer) == 0) { awe_packetProcess(AWEInstance0); writeReplyToServer(); } else if (PACKET_INSTANCEID(AWE_Packet_Buffer) == 16) { sendToInstance16() //command is processed on instance 16 readReplyFromInstance16() writeReplyToServer(); } }
Here is a pseudocode example of a multi-instance tuning interface that is implemented on an MCU that has no knowledge of the AWE Core instance’s. The system has two AWE instances on separate processors, with ID’s of 0 and 16.
TuningInterface() { Tuning_PacketBuffer= receivePacketFromServer() if (PACKET_OPCODE(Tuning_PacketBuffer)) == PFID_GetInstanceTable) { GenerateInstanceTableReply(Tuning_PacketBuffer, numInstances, instanceIDs); writePacketToServer(Tuning_PacketBuffer); } else if (PACKET_INSTANCEID(Tuning_PacketBuffer) == 0) { sendPacketToInstance0(Tuning_PacketBuffer) //Instance 1 gets packet and calls awe_packetProcess receiveReplyPacketFromInstance0() writeReplyToServer() } else if (PACKET_INSTANCEID(AWE_Packet_Buffer) == 16) { sendPacketToInstance16() //Instance 16 gets packet and calls awe_packetProcess receivePacketFromInstance16() writeReplyToServer() } }
This section discusses only the latency caused by the AWE Core framework. The signal processing flow, the firmware, and the hardware can all introduce additional latency to the overall system. In this discussion, a "block" of latency refers to the layout block size and the systems sample rate. For example, with a layout block size of 256 and a sample rate of 48 kHz, the latency through the AWE Core system will be in multiples of blocks of (256 / 48000) = 5.33 ms. AWECore can introduce up to 2 block’s of latency, but can also be configured to achieve 0 blocks of latency under certain conditions.
There are 3 possible latency situations introduced by the AWECore library
Which of the three latency paths will be taken depends on some conditions in the implementation of the AWECore API, and the relationship between the system and the signal processing layout.
Note: The following abbreviations may be used for these AWECore API calls:
To achieve 0 blocks of AWE-induced latency, the following three conditions must be met:
AWE Core has an internal double buffering scheme on the input and output pins to handle situations where a layout’s blocksize is a multiple of the AWEInstance’s fundamental blocksize. For example, a system with a 64 BS layout running on a 32 fundamental BS AWEInstance must complete two, 32-sample audio callbacks before actually pumping audio through the layout (to satisfy the 64 samples). Double buffering is used in this situation in order to store the next frames of data in one buffer, while the processing occurs on the data in the other buffer. Two blocks of latency are introduced by this double buffering of the input and output pins.
However, in a situation where a layout BS is the same as a fundamental BS, the double buffering scheme is not required and two blocks of latency can be avoided. AWECore has an internal mechanism to check if the layout and fundamental blocksizes are equivalent at layout runtime, and will automatically bypass the double buffering to eliminate the introduced latency. Less memory is also consumed under this condition as only a single buffer can be used at the input and output pins.
At a very high level, 0 blocks of latency can only fundamentally be achieved if all of the audio processing occurs in a single callback. Based on this, the audio processing function must implement the following order of API calls to achieve the lowest possible latency: awe_audioImportSamples() awe_audioGetPumpMask() && awe_audioPump() (can be a signal to lower priority threads to do actual pumping) awe_audioExportSamples()
Different orders of API calls will still operate correctly from a processing standpoint, but may not achieve the lowest possible latency.
Virtually all systems that integrate the AWE Core will use a thread signaling or interrupt raising scheme to trigger awe_audioPump in separate, lower priority contexts from the main DMA audio callback. While this scheme is required in order to allow for efficient, multi-rate operation of signal processing layouts, it does mean that the processing of the audio signal will not be complete by the end of the audio callback, As mentioned in the section above, a system with 0 blocks of AWECore induced latency must complete all audio processing within the context of the main DMA audio callback. So in order to achieve minimal latency, the first sublayout (layout index 0) must be executed in place during the audio callback, not in a lower priority context.
The first sublayout consumes the input pin and fills the output pin, so it is only this layout that needs to be processed in place. Other non low latency paths (clockdivided sublayouts, layout index > 0) should still be signaled by the callback and pumped in another context.
There are a few common pitfalls when BSP authors are integrating AWE Core. The most common problems are scheduling issues, specifically when the audio thread is not at a high enough priority and is preempted by the packet or deferred processing. RT audio needs to be running at a very high priority, just below the Tuning Interface IO thread.
