AWECore 8.C.2 API Document
ControlApp.c
Examples
* AWECore Control Example
* Description: AWECore Control Example
* This example shows how to load an .awb from an array, and then
* how to get/set module variables using the corresponding
* controlinterface header file and API's.
* The example will stream an audio file called in_s32_stereo.raw
* and write the processed output to out_s32_stereo.raw.
* This example meets all the conditions to achieve 0 blocks of
* latency in the AWE Core audio path. See the Latency section
* of the docs for more info.
* 3235 Kifer Road
* Santa Clara, CA 95054-1527
#include <float.h>
#include <math.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include "AWECore.h"
#include "Errors.h"
#include "TargetInfo.h"
#include "passthrough_ControlInterface.h"
const char awbFilename[] = "../Designs/passthrough.awb";
const char inFilename[] = "../Audio/in_s32_stereo.raw"; // input audio file: stereo 32-bit fixed-point
const char outFilename[] = "../Audio/out_s32_stereo.raw"; // output audio file: stereo 32-bit fixed-point
// Global AWEInstance structure and pins
AWEInstance aweInstance;
// LISTOFCLASSOBJECTS comes from ModuleList.h
LISTOFCLASSOBJECTS
// Global heaps
UINT32 fastHeapA[FASTA_HEAP_SIZE];
UINT32 fastHeapB[FASTB_HEAP_SIZE];
UINT32 slowHeap[SLOW_HEAP_SIZE];
// Packet buffer
FILE *fin;
FILE *fout;
// Floating-point comparison function used for verification
// Inspired by: http://floating-point-gui.de/errors/comparison/
int isNearlyEqual(float a, float b, float epsilon)
float absA = fabsf(a);
float absB = fabsf(b);
float diff = fabsf(a - b);
if (a == b) { // to handle infinities
return 1;
// a or b is zero or both are extremely close to it
// relative error is less meaningful here
} else { // use relative error
if ((absA + absB) < FLT_MAX)
else
void destroyExample()
fclose(fin);
fclose(fout);
free(inputBuffer);
free(outputBuffer);
inputBuffer = NULL;
outputBuffer = NULL;
void InitializeAWEInstance()
int ret;
//set memory for awe instance and initialize to 0's
memset(&aweInstance, 0, sizeof(AWEInstance));
aweInstance.pInputPin = &aweInputPin;
aweInstance.pOutputPin = &aweOutputPin;
// No tuning interface in this example
aweInstance.pPacketBuffer = awePacketBuffer;
aweInstance.pReplyBuffer = awePacketBuffer;
aweInstance.packetBufferSize = MAX_COMMAND_BUFFER_LEN;
aweInstance.pModuleDescriptorTable = module_descriptor_table;
aweInstance.numModules = module_descriptor_table_size;
aweInstance.numThreads = 1;
aweInstance.sampleRate = SAMPLE_RATE;
aweInstance.fundamentalBlockSize = BASE_BLOCK_SIZE;
aweInstance.pFlashFileSystem = HAS_FLASHFILESYSTEM;
aweInstance.fastHeapASize = FASTA_HEAP_SIZE;
aweInstance.fastHeapBSize = FASTB_HEAP_SIZE;
aweInstance.slowHeapSize = SLOW_HEAP_SIZE;
aweInstance.pFastHeapA = fastHeapA;
aweInstance.pFastHeapB = fastHeapB;
aweInstance.pSlowHeap = slowHeap;
aweInstance.cbAudioStart = NULL;
aweInstance.cbAudioStop = NULL;
aweInstance.coreSpeed = CORE_SPEED;
aweInstance.profileSpeed = PROFILE_SPEED;
aweInstance.pName = NULL;
ret = awe_initPin(&aweInputPin, NUM_INPUT_CHANNELS, NULL);
if (ret != 0)
ret = awe_initPin(&aweOutputPin, NUM_OUTPUT_CHANNELS, NULL);
if (ret != 0)
ret = awe_init(&aweInstance);
if (ret != 0)
printf("awe_init failed\n");
int main() {
INT32 ret = 0;
UINT32 position;
UINT32 inSize, outSize;
InitializeAWEInstance();
// Load the .awb from C array
ret = awe_loadAWBfromArray(&aweInstance, Core0_InitCommands, Core0_InitCommands_Len, &position);
if (ret != E_SUCCESS)
printf("Error loading AWB from array: error = %d, at offset %u\n", ret, position);
exit(1);
ret = awe_layoutIsValid(&aweInstance);
if (ret != 1)
exit(1);
ret = awe_audioIsStarted(&aweInstance);
if (ret != 1)
exit(1);
// Get the layout I/O configuration
// Input and output blocksizes must be the same
//NOTE: Because there can only be one input pin and one output pin, all API's that take the argument "pinIdx" will always pass in 0. This is demonstrated in the function calls below.
awe_layoutGetChannelCount(&aweInstance, 0, &layoutInChannels, &layoutOutChannels);
ret = awe_layoutGetInputBlockSize(&aweInstance, 0, &layoutBlockSize);
printf("Error: GetBlockSize failed: error = %d\n", ret);
exit(1);
printf("Layout loaded with inputChannels=%u, outputChannels=%u, blockSize=%u\n", layoutInChannels, layoutOutChannels, layoutBlockSize);
// Prepare the stereo input and output buffers, and open files
if (fin == NULL)
printf("Error opening file %s\n", inFilename);
exit(1);
if (fout == NULL)
printf("Error opening file %s\n", outFilename);
exit(1);
// Set Scaler1 gain attributes
float scaler1Gain;
float scaler1TargetGain;
long count = 0;
int numSamplesRead = 0;
UINT32 classId;
//NOTE: All handles, IDs, and sizes that are passed into the ctrl interface API functions are found in the example ControlInterface header file "passthrough_ControlInterface.h"
// Check that the layout has the correct control modules in it
int moduleFound = 0;
if (awe_ctrlGetModuleClass(&aweInstance, AWE_Scaler1_gain_HANDLE, &classId) == E_SUCCESS)
// Check that module assigned this object ID is of module class SinkInt
if (classId == AWE_Scaler1_classID)
moduleFound = 1;
if (!moduleFound)
printf("Error: Scaler1 module not found in layout\n");
if (awe_ctrlGetModuleClass(&aweInstance, AWE_Meter1_value_HANDLE, &classId) == E_SUCCESS)
if (classId == AWE_Meter1_classID)
moduleFound = 1;
if (!moduleFound)
printf("Error: Meter1 module not found in layout\n");
printf("\n");
// Set the gain to -10 dB
scaler1Gain = -10.0;
ret = awe_ctrlSetValue(&aweInstance, AWE_Scaler1_gain_HANDLE, (const void *)&scaler1Gain, 0, AWE_Scaler1_gain_SIZE);
ret = awe_ctrlGetValue(&aweInstance, AWE_Scaler1_gain_HANDLE, &scaler1Gain, 0, AWE_Scaler1_gain_SIZE);
ret = awe_ctrlGetValue(&aweInstance, AWE_Scaler1_targetGain_HANDLE, &scaler1TargetGain, 0, AWE_Scaler1_targetGain_SIZE);
// Process the input data
INT32 i, j;
INT32 numOutFrames;
UINT32 pumpMask;
// Import and export samples for each channel in I/O files
ret = awe_audioImportSamples(&aweInstance, inputBuffer + i, inputChannels, i, Sample32bit);
printf("Error: audio import failed: error = %d\n", ret);
// Only one layout in this example, so only bother checking for that field of the pump mask
pumpMask = awe_audioGetPumpMask(&aweInstance);
if (pumpMask & 1U)
// Pump the layout if ready
ret = awe_audioPump(&aweInstance, 0);
printf("Error: audio pump failed: layout=%d, error=%d\n", 0, ret);
ret = awe_audioExportSamples(&aweInstance, outputBuffer + i, outputChannels, i, Sample32bit);
printf("Error: audio export failed: error = %d\n", ret);
count++;
// Print the Meter1 value every 1024 pump cycles
if ((count % 1024) == 0)
ret = awe_ctrlGetValue(&aweInstance, AWE_Meter1_value_HANDLE, &meter1Values, 0, AWE_Meter1_value_SIZE);
// Perform inline verification
// Channel 1 is expected to be attenuated by -10 dB
// Channel 2 is expected to be passed through without modification
#define EPSILON 0.1f
for (j = 0; j < numOutFrames; j++) {
if (isNearlyEqual(expectedValueChannel1, (float)outputBuffer[outputChannels * j], EPSILON) == 0) {
destroyExample();
exit(1);
if (isNearlyEqual(expectedValueChannel2, (float)outputBuffer[outputChannels * j + 1], EPSILON) == 0) {
destroyExample();
exit(1);
// There is no latency through the audio pump
printf("\n");
// Clean up
destroyExample();
return 0;
AWEInstance::cbAudioStop
INT32(* cbAudioStop)(struct AWEInstance *pAWE)
OPTIONAL.
Definition: AWECore.h:141
AWEInstance::sampleRate
float sampleRate
Definition: AWECore.h:226
AWEInstance::numThreads
UINT32 numThreads
Definition: AWECore.h:223
AWEInstance::fastHeapBSize
UINT32 fastHeapBSize
The fast heap B size.
Definition: AWECore.h:124
awe_initPin
awe_ctrlSetValue
INT32 awe_layoutGetInputBlockSize(const AWEInstance *pAWE, UINT32 pinIdx, UINT32 *blockSize)
Returns the block size of a pin.
AWEInstance::coreSpeed
float coreSpeed
Definition: AWECore.h:208
awe_layoutIsValid
AWEInstance::numModules
UINT32 numModules
Definition: AWECore.h:166
AWEInstance::pReplyBuffer
UINT32 * pReplyBuffer
Reply buffer pointer.
Definition: AWECore.h:193
Test if AWE is ready to run.
AWEInstance::pInputPin
IOPinDescriptor * pInputPin
Definition: AWECore.h:150
AWEInstance::pOutputPin
IOPinDescriptor * pOutputPin
Definition: AWECore.h:156
AWEInstance::pFlashFileSystem
Definition: AWECore.h:235
AWEInstance::pName
const char * pName
Name of this instance as a string
Definition: AWECore.h:219
awe_init
Initialize the instance.
AWEInstance::pPacketBuffer
UINT32 * pPacketBuffer
The Packet buffer pointer.
Definition: AWECore.h:184
AWEInstance::packetBufferSize
UINT32 packetBufferSize
Packet buffer size.
Definition: AWECore.h:200
void awe_layoutGetChannelCount(const AWEInstance *pAWE, UINT32 pinIdx, UINT32 *inCount, UINT32 *outCount)
Returns the number of channels in the Layout's input and output pins.
awe_ctrlGetValue
Errors.h
AWEInstance
The AWE instance.
Definition: AWECore.h:100
awe_audioPump
Audio pump function.
E_SUCCESS
#define E_SUCCESS
OK result.
Definition: Errors.h:30
AWEInstance::pSlowHeap
UINT32 * pSlowHeap
The slow heap.
Definition: AWECore.h:116
AWECore.h
The AWECore API Header File.
AWEInstance::cbAudioStart
INT32(* cbAudioStart)(struct AWEInstance *PAWE)
Definition: AWECore.h:135
awe_audioIsStarted
AWEInstance::profileSpeed
float profileSpeed
Profiling clock speed in Hz.
Definition: AWECore.h:211
AWEInstance::fastHeapASize
UINT32 fastHeapASize
The fast heap A size.
Definition: AWECore.h:121
AWEInstance::slowHeapSize
UINT32 slowHeapSize
The slow heap size.
Definition: AWECore.h:127
AWEInstance::pFastHeapA
UINT32 * pFastHeapA
Fast heap A.
Definition: AWECore.h:110
AWEInstance::fundamentalBlockSize
UINT32 fundamentalBlockSize
Definition: AWECore.h:230
IOPinDescriptor
AWE IO Pin type.
Definition: AWECore.h:42
AWEInstance::pFastHeapB
UINT32 * pFastHeapB
The second fast heap, B .
Definition: AWECore.h:113
AWEInstance::pModuleDescriptorTable
const void * pModuleDescriptorTable
Pointer to module table.
Definition: AWECore.h:174
