AWECore 8.C.2 API Document
The AWECore API Header File. More...
#include <stdlib.h>#include <string.h>#include <stddef.h>#include "TargetProcessor.h"Go to the source code of this file.
Data Structures | |
| struct | IOPinDescriptor |
| AWE IO Pin type. More... | |
| struct | AWEFlashFSInstance |
| The DSPC Flash File System Instance. More... | |
| struct | AWEInstance |
| The AWE instance. More... | |
Typedefs | |
| typedef struct IOPinDescriptor | IOPinDescriptor |
| typedef struct AWEFlashFSInstance | AWEFlashFSInstance |
| typedef struct AWEInstance | AWEInstance |
| typedef INT32 | packetProcessFunction(AWEInstance *pAWE) |
Functions | |
| INT32 | awe_init (AWEInstance *pAWE) |
| Initialize the instance. More... | |
| INT32 | awe_initPin (IOPinDescriptor *pPin, UINT32 channels, const char *name) |
| Initialize an input or output pin. More... | |
| void | awe_initFlashFS (AWEInstance *pAWE, AWEFlashFSInstance *pAWEFlashFSInstance) |
| Initialize the file system. More... | |
| INT32 | awe_packetProcess (AWEInstance *pAWE) |
| Process an AWEInstance's newly received tuning packet. More... | |
| INT32 | awe_audioPump (AWEInstance *pAWE, UINT32 layoutIndex) |
| Audio pump function. More... | |
| INT32 | awe_audioImportSamples (const AWEInstance *pAWE, const void *inSamples, INT32 inStride, INT32 channel, SampleType inType) |
| Import samples from a user buffer to a channel. More... | |
| INT32 | awe_audioExportSamples (const AWEInstance *pAWE, void *outSamples, INT32 outStride, INT32 channel, SampleType outType) |
| Export samples to a user buffer from a channel. More... | |
| INT32 | awe_audioIsStarted (const AWEInstance *pAWE) |
| Check if this instance is running. More... | |
| INT32 | awe_audioGetPumpMask (AWEInstance *pAWE) |
| Test if AWE is ready to run. More... | |
| INT32 | awe_deferredSetCall (AWEInstance *pAWE) |
| Perform deferred awe set on a module. More... | |
| INT32 | awe_loadAWBfromArray (AWEInstance *pAWE, const UINT32 *pCommands, UINT32 arraySize, UINT32 *pPos) |
| Executes packet commands from an in-memory array. More... | |
| void | awe_layoutGetChannelCount (const AWEInstance *pAWE, UINT32 pinIdx, UINT32 *inCount, UINT32 *outCount) |
| Returns the number of channels in the Layout's input and output pins. More... | |
| INT32 | awe_layoutGetInputBlockSize (const AWEInstance *pAWE, UINT32 pinIdx, UINT32 *blockSize) |
| Returns the block size of a pin. More... | |
| INT32 | awe_layoutGetInputSampleRate (const AWEInstance *pAWE, UINT32 pinIdx, FLOAT32 *sampleRate) |
| Returns the sample rate of an input pin. More... | |
| INT32 | awe_layoutIsValid (const AWEInstance *pAWE) |
| Determines if a layout is loaded and valid. More... | |
| INT32 | awe_ctrlSetValue (const AWEInstance *pAWE, UINT32 handle, const void *value, INT32 arrayOffset, UINT32 length) |
| Set a scalar or array value of a module variable by handle. More... | |
| INT32 | awe_ctrlGetValue (const AWEInstance *pAWE, UINT32 handle, void *value, INT32 arrayOffset, UINT32 length) |
| Get a scalar or array value of a module variable by handle. More... | |
| INT32 | awe_ctrlSetStatus (const AWEInstance *pAWE, UINT32 handle, UINT32 status) |
| Set the runtime status of a module. More... | |
| INT32 | awe_ctrlGetStatus (const AWEInstance *pAWE, UINT32 handle, UINT32 *status) |
| Get the runtime status of a module. More... | |
| INT32 | awe_ctrlSetValueMask (const AWEInstance *pAWE, UINT32 handle, const void *value, INT32 arrayOffset, UINT32 length, UINT32 mask) |
| Set a scalar or array value of a module variable by handle with mask. More... | |
| INT32 | awe_ctrlGetValueMask (const AWEInstance *pAWE, UINT32 handle, void *value, INT32 arrayOffset, UINT32 length, UINT32 mask) |
| Get a scalar or array value of a module variable by handle with mask. More... | |
| INT32 | awe_ctrlGetModuleClass (const AWEInstance *pAWE, UINT32 handle, UINT32 *pClassID) |
| Get an object class from its handle. More... | |
| INT32 | awe_setProfilingStatus (AWEInstance *pAWE, UINT32 enable) |
| Enable or disable the profiling ability of the AWECore. More... | |
| INT32 | awe_getAverageLayoutCycles (AWEInstance *pAWE, UINT32 layoutIdx, UINT32 *averageCycles) |
| Get the average cycles of a running layout, in units of cycles at profileSpeed. More... | |
| typedef struct IOPinDescriptor IOPinDescriptor |
AWE IO Pin type.
The AWE typedef for input/output pins. A BSP author will allocate their input/output pins of this type.
| typedef struct AWEFlashFSInstance AWEFlashFSInstance |
Optional – SINGLE INSTANCE ONLY
| typedef struct AWEInstance AWEInstance |
The AWE instance.
| INT32 awe_init | ( | AWEInstance * | pAWE | ) |
Call this once you have assigned all of the required members/pointers of the AWE Instance, and after calling awe_InitPin on both input and output pins. Calling awe_init before assigning all members of the instance structure or initializing the pins will result in crashes/erratic behavior.
| pAWE | instance to initialize |
| INT32 awe_initPin | ( | IOPinDescriptor * | pPin, |
| UINT32 | channels, | ||
| const char * | name | ||
This function must be called for both the input and output pins. Must be called BEFORE the awe_init API function.
| [in] | pPin | the pin instance to initialize |
| [in] | channels | number of channels |
| [in] | name | optional pin name |
| void awe_initFlashFS | ( | AWEInstance * | pAWE, |
| AWEFlashFSInstance * | pAWEFlashFSInstance | ||
| pAWEFlashFSInstance | the file system instance |
| INT32 awe_packetProcess | ( | AWEInstance * | pAWE | ) |
| [in] | pAWE | The AWE instance pointer to process |
| INT32 awe_audioPump | ( | AWEInstance * | pAWE, |
| UINT32 | layoutIndex | ||
Call this in your audio thread once you have imported the data you wish to process. Before pumping, you must also check that the AudioWeaver buffers have been filled (awe_getPumpMask) and that audio has been started (awe_audioIsStarted). This function will return 1 if awe_deferredSetCall needs to be called. This is for modules that need to do more time consuming calculations, like calculating filter coefficients. For example, a SOF Control module needs to calculate new coeffs when the frequency is modified by the control input.
| [in] | pAWE | AWE instance pointer |
| [in] | layoutIndex | the layout index to pump |
| INT32 awe_audioImportSamples | ( | const AWEInstance * | pAWE, |
| const void * | inSamples, | ||
| INT32 | inStride, | ||
| INT32 | channel, | ||
| SampleType | inType | ||
The value of the fundamentalBlockSize member of the AWEInstance determines the number of samples that are imported with each call. Call this function once for each audio input channel on the hardware. Channel matching between hardware capabilities and layout will be done automatically. For example, if the target has only 1 audio input channel, and if a layout with 3 input channels is loaded, the second and third channels of the layout input will be all zeros. Inversely, if there are more HW input channels than the layout expects, then they are ignored.
The value of inStride defines the number of samples to skip between each read, and should be the number of interleaved channels in the inSamples buffer being read from. A typical usage for a single source, interleaved stereo input could look like:
| [in] | pAWE | AWE instance |
| [in] | inSamples | pointer to first sample in buffer to import for current channel |
| [in] | inStride | input buffer import stride |
| [in] | channel | channel to write to |
| INT32 awe_audioExportSamples | ( | const AWEInstance * | pAWE, |
| void * | outSamples, | ||
| INT32 | outStride, | ||
| SampleType | outType | ||
The value of the fundamentalBlockSize member of the AWEInstance determines the number of samples that are exported with each call. Call this function once for each audio output channel on the hardware. Like awe_audioImportSamples, this will do channel matching automatically. For example, if the target has 3 audio output channels, and if a layout with 1 output channel is loaded, the second and third channels of the exported output will be all zeros. Inversely, if the layout has more output channels than the target supports, they are ignored.
| [out] | outSamples | pointer to first sample in buffer to export to |
| [in] | outStride | output buffer export stride |
| [in] | channel | channel to read from |
| INT32 awe_audioIsStarted | ( | const AWEInstance * | pAWE | ) |
A BSP author can use this to determine if the instance is already running to avoid pumping audio through a dead layout.
| pAWE | instance pointer |
| INT32 awe_audioGetPumpMask | ( | AWEInstance * | pAWE | ) |
This will return the "layout mask" which is a bit vector of threads to run. For a simple, single threaded system, the bitvector will be 0x1. If a previous pump is not complete and the layout is ready to pump again, an overflow is detected by this function. In this condition, the layoutMask bit for the overflowed layout will be zero, which prevents the layout from being pumped again. Example: int layoutMask = awe_audioGetPumpMask&g_AWEInstance); if (layoutMask > 0) { if (layoutMask & 0x1) { int ret = awe_audioPump(&g_AWEInstance, 0); } }
| INT32 awe_deferredSetCall | ( | AWEInstance * | pAWE | ) |
Each call to awe_deferredSetCall processes a single module. Usually this function would be called repeatedly until the return value is 0.
| INT32 awe_loadAWBfromArray | ( | AWEInstance * | pAWE, |
| const UINT32 * | pCommands, | ||
| UINT32 | arraySize, | ||
| UINT32 * | pPos | ||
Designer can generate AWB arrays directly from a layout.
| [in] | pCommands | Buffer with commands to execute |
| [in] | arraySize | Number of DWords in command buffer |
| [out] | pPos | Report failing word index |
| void awe_layoutGetChannelCount | ( | const AWEInstance * | pAWE, |
| UINT32 | pinIdx, | ||
| UINT32 * | inCount, | ||
| UINT32 * | outCount | ||
| [in] | pinIdx | which input pin (always 0) |
| [out] | inCount | channels in primary input pin |
| [out] | outCount | channels in primary output pin |
| INT32 awe_layoutGetInputBlockSize | ( | const AWEInstance * | pAWE, |
| UINT32 * | blockSize | ||
Because the block size of the output pin is inherited from the input pin, the user only needs to check the input pin.
| [in] | pAWE | The AWE Instance |
| [out] | blockSize | block size of input pin |
| INT32 awe_layoutGetInputSampleRate | ( | const AWEInstance * | pAWE, |
| FLOAT32 * | sampleRate | ||
Because the sample rate of the output pin is inherited from the input pin, the user only needs to check the input pin.
| [out] | sampleRate | the input pin sample rate |
| INT32 awe_layoutIsValid | ( | const AWEInstance * | pAWE | ) |
| INT32 awe_ctrlSetValue | ( | const AWEInstance * | pAWE, |
| UINT32 | handle, | ||
| const void * | value, | ||
| INT32 | arrayOffset, | ||
| UINT32 | length | ||
| [in] | pAWE | instance pointer |
| [in] | arrayOffset | array index if array |
| [in] | length | number of elements. 1 if scaler |
| INT32 awe_ctrlGetValue | ( | const AWEInstance * | pAWE, |
| INT32 awe_ctrlSetStatus | ( | const AWEInstance * | pAWE, |
| UINT32 | status | ||
0 = Active, 1 = Bypass, 2 = Mute, 3 = Inactive
| INT32 awe_ctrlGetStatus | ( | const AWEInstance * | pAWE, |
| UINT32 * | status | ||
| [out] | status | status to get |
| INT32 awe_ctrlSetValueMask | ( | const AWEInstance * | pAWE, |
| UINT32 | length, | ||
| UINT32 | mask | ||
A mask allows you to only call module's set function for a single variable.
| [in] | length | number of elements if array. 1 if scaler |
| [in] | mask | mask to use - 0 to not call set function |
| INT32 awe_ctrlGetValueMask | ( | const AWEInstance * | pAWE, |
| UINT32 | mask | ||
| INT32 awe_ctrlGetModuleClass | ( | const AWEInstance * | pAWE, |
| UINT32 * | pClassID | ||
| pAWE | instance pointer | |
| INT32 awe_setProfilingStatus | ( | AWEInstance * | pAWE, |
| UINT32 | enable | ||
Enabled by default at awe_init. Use this if you wish to enable or disable per pump profiling during runtime. Disabling profiling saves a small amount of cycles per pump.
| enable | 0 for disabled, 1 for enabled |
| INT32 awe_getAverageLayoutCycles | ( | AWEInstance * | pAWE, |
| UINT32 | layoutIdx, | ||
Returns cycles in 24.8 format, so shift right by 8 bits for integer value. To get CPU cycles, multiply by target cpuSpeed / profileSpeed. If a previous pump is not complete and the layout is ready to pump again, an overflow is detected. In when in this state, the awe_getAverageLayoutCycles api will return the averageCycles = AWE_PUMP_OVF_MAX_AVG_CYCLES (0xFFFFFFFF).
| layoutIdx | Layout index (typically 0, except in advanced use cases) |
| averageCycles | Pointer the output (average layout cycles) |
1.8.16
