AWECore 8.C.2 API Document
The DSPC Flash File System Instance. More...
#include <Include/AWECore.h>
Data Fields | |
| UINT32 | flashSizeInBytes |
| Size of flash memory - if non-zero, next two values must also be non-zero. | |
| UINT32 | flashErasableBlockSizeInBytes |
| Size of flash erase block. | |
| UINT32 | flashStartOffsetInBytes |
| Offset into start of flash used for file system. | |
| UINT32 | flashEraseTimeInMs |
| Flash erase time in milliseconds. | |
| BOOL(* | cbInit )(void) |
| User function to initialize flash file system. | |
| BOOL(* | cbEraseSector )(UINT32 nStartingAddress, UINT32 nNumberOfSectors) |
| User callback function to erase one or more sectors. | |
| BOOL(* | cbFlashWrite )(UINT32 nFlashAddress, UINT32 *pBuffer, UINT32 nDWordsToWrite) |
| User callback function to write to flash. | |
| BOOL(* | cbFlashRead )(UINT32 nFlashAddress, UINT32 *pBuffer, UINT32 nDWordsToRead) |
| User function to read from flash. | |
| INT32(* | cbFlashProcessCmd )(struct AWEInstance *pAWE) |
| Optional user callback function to return the next command from an awb in flash. More... | |
| UINT32 | _Reserved [62] |
| Reserved member. | |
Optional – SINGLE INSTANCE ONLY
| INT32(* AWEFlashFSInstance::cbFlashProcessCmd) (struct AWEInstance *pAWE) |
Only required for multi-instance BSPs. If not defined, awb commands are processed internally in the associated AWEInstance.
The command to be processed is in pAWE->pPacketBuffer. Parse the instanceID/opcode with AWECoreUtils, and route/process it on the desired instance.
1.8.16
