AWECore 8.C.2 API Document
Go to the documentation of this file.
33 #include "TargetProcessor.h"
74 BOOL (*
cbEraseSector)(UINT32 nStartingAddress, UINT32 nNumberOfSectors);
77 BOOL (*
cbFlashWrite)(UINT32 nFlashAddress, UINT32 * pBuffer, UINT32 nDWordsToWrite);
80 BOOL (*
cbFlashRead)(UINT32 nFlashAddress, UINT32 * pBuffer, UINT32 nDWordsToRead);
273 typedef INT32 packetProcessFunction(
AWEInstance * pAWE);
543 #endif // _FRAMEWORK_H
INT32(* cbAudioStop)(struct AWEInstance *pAWE)
OPTIONAL.
Definition: AWECore.h:141
float sampleRate
Definition: AWECore.h:226
BOOL(* cbFlashWrite)(UINT32 nFlashAddress, UINT32 *pBuffer, UINT32 nDWordsToWrite)
User callback function to write to flash.
Definition: AWECore.h:77
UINT32 numThreads
Definition: AWECore.h:223
UINT32 fastHeapBSize
The fast heap B size.
Definition: AWECore.h:124
INT32 awe_ctrlGetStatus(const AWEInstance *pAWE, UINT32 handle, UINT32 *status)
Get the runtime status of a module.
INT32 awe_getAverageLayoutCycles(AWEInstance *pAWE, UINT32 layoutIdx, UINT32 *averageCycles)
INT32 awe_layoutGetInputBlockSize(const AWEInstance *pAWE, UINT32 pinIdx, UINT32 *blockSize)
Returns the block size of a pin.
float coreSpeed
Definition: AWECore.h:208
void awe_initFlashFS(AWEInstance *pAWE, AWEFlashFSInstance *pAWEFlashFSInstance)
Initialize the file system.
INT32 awe_ctrlSetStatus(const AWEInstance *pAWE, UINT32 handle, UINT32 status)
Set the runtime status of a module.
UINT32 _Reserved[52]
Internal members.
Definition: AWECore.h:238
UINT32 numModules
Definition: AWECore.h:166
INT32 awe_layoutGetInputSampleRate(const AWEInstance *pAWE, UINT32 pinIdx, FLOAT32 *sampleRate)
Returns the sample rate of an input pin.
struct AWEFlashFSInstance AWEFlashFSInstance
The DSPC Flash File System Instance.
struct IOPinDescriptor IOPinDescriptor
AWE IO Pin type.
UINT32 flashEraseTimeInMs
Flash erase time in milliseconds.
Definition: AWECore.h:68
BOOL(* cbFlashRead)(UINT32 nFlashAddress, UINT32 *pBuffer, UINT32 nDWordsToRead)
User function to read from flash.
Definition: AWECore.h:80
UINT32 * pReplyBuffer
Reply buffer pointer.
Definition: AWECore.h:193
struct AWEInstance AWEInstance
The AWE instance.
Test if AWE is ready to run.
IOPinDescriptor * pInputPin
Definition: AWECore.h:150
IOPinDescriptor * pOutputPin
Definition: AWECore.h:156
Definition: AWECore.h:235
UINT32 flashSizeInBytes
Size of flash memory - if non-zero, next two values must also be non-zero.
Definition: AWECore.h:59
BOOL(* cbEraseSector)(UINT32 nStartingAddress, UINT32 nNumberOfSectors)
User callback function to erase one or more sectors.
Definition: AWECore.h:74
const char * pName
Name of this instance as a string
Definition: AWECore.h:219
Initialize the instance.
UINT32 flashErasableBlockSizeInBytes
Size of flash erase block.
Definition: AWECore.h:62
INT32 awe_ctrlGetValueMask(const AWEInstance *pAWE, UINT32 handle, void *value, INT32 arrayOffset, UINT32 length, UINT32 mask)
Get a scalar or array value of a module variable by handle with mask.
UINT32 * pPacketBuffer
The Packet buffer pointer.
Definition: AWECore.h:184
UINT32 packetBufferSize
Packet buffer size.
Definition: AWECore.h:200
void awe_layoutGetChannelCount(const AWEInstance *pAWE, UINT32 pinIdx, UINT32 *inCount, UINT32 *outCount)
Returns the number of channels in the Layout's input and output pins.
The AWE instance.
Definition: AWECore.h:100
Audio pump function.
UINT32 userVersion
User Version word.
Definition: AWECore.h:205
UINT32 _Reserved[62]
Reserved member.
Definition: AWECore.h:88
UINT32 * pSlowHeap
The slow heap.
Definition: AWECore.h:116
UINT32 flashStartOffsetInBytes
Offset into start of flash used for file system.
Definition: AWECore.h:65
INT32(* cbAudioStart)(struct AWEInstance *PAWE)
Definition: AWECore.h:135
UINT32 _Reserved[82]
Reserved member.
Definition: AWECore.h:45
INT32 awe_setProfilingStatus(AWEInstance *pAWE, UINT32 enable)
Enable or disable the profiling ability of the AWECore.
INT32 awe_ctrlSetValueMask(const AWEInstance *pAWE, UINT32 handle, const void *value, INT32 arrayOffset, UINT32 length, UINT32 mask)
Set a scalar or array value of a module variable by handle with mask.
UINT32 instanceId
The ID of this instance.
Definition: AWECore.h:106
Definition: AWECore.h:56
float profileSpeed
Profiling clock speed in Hz.
Definition: AWECore.h:211
UINT32 fastHeapASize
The fast heap A size.
Definition: AWECore.h:121
INT32(* cbFlashProcessCmd)(struct AWEInstance *pAWE)
Optional user callback function to return the next command from an awb in flash.
Definition: AWECore.h:85
UINT32 slowHeapSize
The slow heap size.
Definition: AWECore.h:127
UINT32 * pFastHeapA
Fast heap A.
Definition: AWECore.h:110
UINT32 fundamentalBlockSize
Definition: AWECore.h:230
AWE IO Pin type.
Definition: AWECore.h:42
UINT32 * pFastHeapB
The second fast heap, B .
Definition: AWECore.h:113
BOOL(* cbInit)(void)
User function to initialize flash file system.
Definition: AWECore.h:71
const void * pModuleDescriptorTable
Pointer to module table.
Definition: AWECore.h:174
