AWECore 8.C.2 API Document
singleinstance_simple.c
A very simple example of a single instance integration without real-time audio on Linux. Ethernet tuning interface. Examples
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
#include <sys/types.h>
#include <sys/socket.h>
#include <netinet/in.h>
#include <pthread.h>
#include "AWECore.h"
#include "ProxyIDs.h"
#include "AWECoreUtils.h"
#include "TargetInfo.h"
AWEInstance g_AWEInstance;
static IOPinDescriptor g_InputPin[1];
static IOPinDescriptor g_OutputPin[1];
const void* g_module_descriptor_table[] =
LISTOFCLASSOBJECTS
** Specify the size in 32-bit words of each of the heaps on this target
#define MASTER_HEAP_SIZE (1024*1024)
#define FASTB_HEAP_SIZE (1024*1024)
#define SLOW_HEAP_SIZE (1024*1024)
UINT32 g_FastHeapA[MASTER_HEAP_SIZE];
UINT32 g_SlowHeap[MASTER_HEAP_SIZE];
UINT32 g_FastHeapB[MASTER_HEAP_SIZE];
//global packet buffers
UINT32 AWE_Packet_Buffer[264];
UINT32 AWE_Packet_Buffer_Reply[264];
void error(const char *msg)
perror(msg);
exit(1);
void *tuningPacketRxThread(void*)
Tuning packets can be recieved and processed here. Another implementation
may choose to process the packet in another thread.
int sockfd, newsockfd;
socklen_t clilen;
unsigned char buffer[264];
int n;
if (sockfd < 0)
error("ERROR opening socket");
bzero((char *) &serv_addr, sizeof(serv_addr));
serv_addr.sin_port = htons(15098);
sizeof(serv_addr)) < 0)
error("ERROR on binding");
listen(sockfd,5);
clilen = sizeof(cli_addr);
newsockfd = accept(sockfd,
&clilen);
if (newsockfd < 0)
error("ERROR on accept");
int i=1;
/* Enter a tuning loop. This will be in a separate thread */
printf( "entering loop ...\n");
while(1)
bzero(AWE_Packet_Buffer,264);
n = read(newsockfd,AWE_Packet_Buffer,264*sizeof(AWE_Packet_Buffer[0]));
if (n < 0) error("ERROR reading from socket");
volatile INT32 opcode = PACKET_OPCODE(AWE_Packet_Buffer);
volatile UINT32 packetInstanceID = PACKET_INSTANCEID(AWE_Packet_Buffer); //snoop the instance ID off of the packet
awe_packetProcess(&g_AWEInstance);
unsigned int plen = AWE_Packet_Buffer[0]>>16;
n = write(newsockfd,AWE_Packet_Buffer,plen*sizeof(AWE_Packet_Buffer[0]));
if (n < 0) error("ERROR writing to socket");
close(newsockfd);
close(sockfd);
void InitializeAWEInstance()
int ret = 0;
//set memory for awe instance and initialize to 0's
memset(&g_AWEInstance, 0, sizeof(AWEInstance));
g_AWEInstance.instanceId = 0;
g_AWEInstance.pInputPin = g_InputPin;
g_AWEInstance.pOutputPin = g_OutputPin;
g_AWEInstance.pPacketBuffer = AWE_Packet_Buffer;
g_AWEInstance.pReplyBuffer = AWE_Packet_Buffer;
g_AWEInstance.packetBufferSize = 264;
g_AWEInstance.pModuleDescriptorTable = g_module_descriptor_table;
UINT32 module_descriptor_table_size = sizeof(g_module_descriptor_table) / sizeof(g_module_descriptor_table[0]);
g_AWEInstance.numModules = module_descriptor_table_size;
g_AWEInstance.numThreads = 1;
g_AWEInstance.sampleRate = 48000.f;
g_AWEInstance.fundamentalBlockSize = 32;
g_AWEInstance.pFlashFileSystem = 0;
g_AWEInstance.fastHeapASize = MASTER_HEAP_SIZE;
g_AWEInstance.slowHeapSize = SLOW_HEAP_SIZE;
g_AWEInstance.fastHeapBSize = FASTB_HEAP_SIZE;
g_AWEInstance.pFastHeapA = g_FastHeapA;
g_AWEInstance.pSlowHeap = g_SlowHeap;
g_AWEInstance.pFastHeapB = g_FastHeapB;
g_AWEInstance.coreSpeed = 10e6f;
g_AWEInstance.profileSpeed = 10e6f;
g_AWEInstance.pName = TARGET_NAME;
ret = awe_initPin(g_InputPin, INPUT_CHANNEL_COUNT, NULL);
if (ret != 0)
ret = awe_initPin(g_OutputPin, OUTPUT_CHANNEL_COUNT, NULL);
if (ret != 0)
ret = awe_init(&g_AWEInstance);
if (ret != 0)
pthread_t rxthread_id;
pthread_t processthread_id;
InitializeAWEInstance();
pthread_create(&rxthread_id, NULL, tuningPacketRxThread, NULL);
pthread_join(rxthread_id, NULL);
while(1)
//printf("main idle loop")
AWEInstance::sampleRate
float sampleRate
Definition: AWECore.h:226
AWEInstance::numThreads
UINT32 numThreads
Definition: AWECore.h:223
AWEInstance::fastHeapBSize
UINT32 fastHeapBSize
The fast heap B size.
Definition: AWECore.h:124
awe_initPin
AWEInstance::coreSpeed
float coreSpeed
Definition: AWECore.h:208
AWECoreUtils.h
AWEInstance::numModules
UINT32 numModules
Definition: AWECore.h:166
AWEInstance::pReplyBuffer
UINT32 * pReplyBuffer
Reply buffer pointer.
Definition: AWECore.h:193
AWEInstance::pInputPin
IOPinDescriptor * pInputPin
Definition: AWECore.h:150
AWEInstance::pOutputPin
IOPinDescriptor * pOutputPin
Definition: AWECore.h:156
AWEInstance::pFlashFileSystem
Definition: AWECore.h:235
AWEInstance::pName
const char * pName
Name of this instance as a string
Definition: AWECore.h:219
awe_init
Initialize the instance.
PACKET_OPCODE
#define PACKET_OPCODE(x)
Get the OPCODE of the packet.
Definition: AWECoreUtils.h:47
AWEInstance::pPacketBuffer
UINT32 * pPacketBuffer
The Packet buffer pointer.
Definition: AWECore.h:184
AWEInstance::packetBufferSize
UINT32 packetBufferSize
Packet buffer size.
Definition: AWECore.h:200
AWEInstance
The AWE instance.
Definition: AWECore.h:100
AWEInstance::pSlowHeap
UINT32 * pSlowHeap
The slow heap.
Definition: AWECore.h:116
AWECore.h
The AWECore API Header File.
PACKET_INSTANCEID
#define PACKET_INSTANCEID(x)
This will get the instance ID of a packet.
Definition: AWECoreUtils.h:43
ProxyIDs.h
AWEInstance::instanceId
UINT32 instanceId
The ID of this instance.
Definition: AWECore.h:106
AWEInstance::profileSpeed
float profileSpeed
Profiling clock speed in Hz.
Definition: AWECore.h:211
AWEInstance::fastHeapASize
UINT32 fastHeapASize
The fast heap A size.
Definition: AWECore.h:121
awe_packetProcess
AWEInstance::slowHeapSize
UINT32 slowHeapSize
The slow heap size.
Definition: AWECore.h:127
AWEInstance::pFastHeapA
UINT32 * pFastHeapA
Fast heap A.
Definition: AWECore.h:110
AWEInstance::fundamentalBlockSize
UINT32 fundamentalBlockSize
Definition: AWECore.h:230
IOPinDescriptor
AWE IO Pin type.
Definition: AWECore.h:42
AWEInstance::pFastHeapB
UINT32 * pFastHeapB
The second fast heap, B .
Definition: AWECore.h:113
AWEInstance::pModuleDescriptorTable
const void * pModuleDescriptorTable
Pointer to module table.
Definition: AWECore.h:174
