More...
#include "ProxyIDs.h"
#include "Errors.h"
#include "TargetProcessor.h"
#define  | PACKET_LENGTH_WORDS(x)   (x[0]>>16) |
|   | This will determine the length of a packet in words.
#define  | PACKET_LENGTH_BYTES(x)   ((x[0]>>16) * sizeof(x[0])) |
|   | This will determine the length of a packet in bytes.
| #define  | PACKET_INSTANCEID(x)   (x[0] >> 8) & 0xff |
|   | This will get the instance ID of a packet.  More...
| #define  | PACKET_OPCODE(x)   ((INT32)x[0] & 0xffU) |
|   | Get the OPCODE of the packet.  More...
#define  | AWB_DONE   1 |
|   | return value that indicates that the end of the AWB has been reached
#define  | AWB_NOT_DONE   0 |
|   | return value that indicates that the end of the AWB has been reached and another command should be processed
#define  | INCOMPLETE_PACKET   0 |
#define  | COMPLETE_NEW_PACKET   1 |
#define  | COMPLETE_REPEATED_PACKET   2 |
| void  | GenerateInstanceTableReply (UINT32 *pPacketBuffer, UINT32 numInstances, UINT32 *pInstanceTable) |
|   | Generate an instance table reply for Server based on the arguments.  More...
| INT32  | float_to_fract32 (FLOAT32 x) |
|   | Convert audio data from floating point to Fract32 sample by sample.  More...
| FLOAT32  | fract32_to_float (INT32 x) |
|   | Convert audio data from fract32 to float sample by sample.  More...
| INT32  | awe_getNextAWBCmd (const UINT32 *pArray, UINT32 arraySize, UINT32 *pErrorOffset, UINT32 *pPacketBuffer) |
|   | Get the next command from an array of AWB commands and write it into a packetBuffer to be processed.  More...
◆ PACKET_INSTANCEID
          | #define PACKET_INSTANCEID |
          x | ) |
- Examples
 - singleinstance_simple.c.
◆ PACKET_OPCODE
          | #define PACKET_OPCODE |
          x | ) |
- Examples
◆ GenerateInstanceTableReply()
          | void GenerateInstanceTableReply  |
          UINT32 *  |
          pPacketBuffer,  |
          UINT32  |
          numInstances,  |
          UINT32 *  |
          pInstanceTable  |
- Parameters
    | [out] | pPacketBuffer | pointer to your instance's packet buffer  |
    | [in] | numInstances | number of instances on your system  |
    | [in] | pInstanceTable | pointer to your instanceID's table  |
◆ float_to_fract32()
          | INT32 float_to_fract32  |
          FLOAT32  |
          x | ) |
- Parameters
    | [in] | x | The floating point value that you wish to convert  |
- Returns
 - The converted value in fract32 format
- Examples
 - LinuxApp.c.
◆ fract32_to_float()
          | FLOAT32 fract32_to_float  |
          INT32  |
          x | ) |
- Parameters
    | [in] | x | The fract32 point value that you wish to convert  |
- Returns
 - The converted value as a float
◆ awe_getNextAWBCmd()
          | INT32 awe_getNextAWBCmd  |
          const UINT32 *  |
          pArray,  |
          UINT32  |
          arraySize,  |
          UINT32 *  |
          pErrorOffset,  |
          UINT32 *  |
          pPacketBuffer  |
- Parameters
    | [in] | *pArray | The AWB array  |
    | [in] | arraySize | The size of the AWB array  |
    | [out] | *pErrorOffset | current position in the array (index of command)  |
    | [in] | *pPacketBuffer | The packetBuffer to write the next command into.  |
- Returns
 - AWB_NOT_DONE if processing of array is not complete
