Enumeration of Proxy function IDs.
Enumerator |
PFID_Undefined | Undefined ID - zero.
PFID_SetCall | Function ID for awe_fwSetCall().
PFID_GetCall | Function ID for awe_fwGetCall().
PFID_GetClassType | Function ID for awe_fwGetClassType().
PFID_GetPinType | Function ID for awe_fwGetPinType().
PFID_ClassWire_Constructor | Function ID for ClassWire_Constructor().
PFID_BindIOToWire | Function ID for BindIOToWire().
PFID_FetchValue | Function ID for awe_fwFetchValue().
PFID_SetValue | Function ID for awe_fwSetValue().
PFID_GetHeapCount | Function ID for awe_fwGetHeapCount().
PFID_GetHeapSize | Function ID for awe_fwGetHeapSize().
PFID_Destroy | Function ID for awe_fwDestroy().
PFID_GetCIModuleCount | Function ID for awe_fwGetCIModuleCount().
PFID_GetCIModuleInfo | Function ID for awe_fwGetCIModuleInfo().
PFID_ClassModule_Constructor | Function ID for ClassModule_Constructor().
PFID_ClassLayout_Constructor | Function ID for ClassLayout_Constructor().
PFID_SetWire | Function ID for awe_fwSetWire().
PFID_GetWire | Function ID for awe_fwGetWire().
PFID_SetModuleState | Function ID for awe_fwSetModuleState().
PFID_GetModuleState | Function ID for awe_fwGetModuleState().
PFID_PumpModule | Function ID for awe_fwPumpModule().
PFID_ClassLayout_Process | Function ID for ClassLayout_Process().
PFID_GetFirstObject | Function ID for awe_fwGetFirstObject().
PFID_GetNextObject | Function ID for awe_fwGetNextObject().
PFID_GetFirstIO | Function ID for awe_fwGetFirstIO().
PFID_GetNextIO | Function ID for awe_fwGetNextIO().
PFID_StartAudio | Function ID for StartAudio().
PFID_StopAudio | Function ID for StopAudio().
PFID_FetchValues | Function ID for awe_fwFetchValue().
PFID_SetValues | Function ID for awe_fwSetValue().
PFID_GetSizeofInt | Function ID for awe_fwGetSizeofInt().
PFID_GetFirstFile | Function ID for awe_GetFirstFile().
PFID_GetNextFile | Function ID for awe_GetNextFile().
PFID_OpenFile | Function ID for awe_OpenFile().
PFID_ReadFile | Function ID for awe_ReadFile().
PFID_WriteFile | Function ID for awe_WriteFile().
PFID_CloseFile | Function ID for awe_CloseFile().
PFID_DeleteFile | Function ID for awe_DeleteFile().
PFID_ExecuteFile | Function ID for awe_ExecuteFile().
PFID_EraseFlash | Function ID for awe_EraseFlash().
PFID_GetTargetInfo | Function ID for awe_GetTargetInfo().
PFID_GetFileSystemInfo | Function ID for awe_GetFileSystemInfo().
PFID_GetProfileValues | Function ID for awe_fwGetProfileValues().
PFID_FileSystemReset | Function ID for awe_FileSystemReset().
PFID_GetObjectByIndex | Function ID for awe_fwGetNextObject().
PFID_GetObjectByID | Function ID for awe_fwGetObjectByID().
PFID_AddModuleToLayout | Function ID for awe_fwAddModuleToLayout().
PFID_SetValueCall | Function ID for awe_fwSetValue() awe_fwSetCall().
PFID_UpdateFirmware | Command ID for update firmware() awe_fwSetCall().
PFID_FlashReadOpen | Command ID for FlashContent Read() awe_fwSetCall().
PFID_FlashRead | Command ID for FlashContent Read() awe_fwSetCall().
PFID_AllocateHeaps | Allocate framework heaps.
PFID_DestroyHeaps | Destroy framework heaps.
PFID_WritePumpRead | Single message write-pump-read combo.
PFID_SetID | Set an object's ID.
PFID_SetValueSetCall | Function ID for awe_fwSetValue() followed by awe_fwSetCall.
PFID_SetValuesSetCall | Function ID for awe_fwSetValues() followed by awe_fwSetCall.
PFID_GetCallFetchValue | Function ID for awe_GetCall() followed by awe_fwFetchValue().
PFID_GetCallFetchValues | Function ID for awe_GetCall() followed by awe_fwFetchValues().
PFID_SetPointer | Function ID for awe_fwSetPointer().
PFID_CreateLookupTable | Function ID for awe_fwcreateLookupTable().
PFID_UpdateLookupTable | Function ID for awe_fwSUpdateLookupTable().
PFID_PumpLayout | Function ID for awe_fwPumpLayout().
PFID_DerefPointer | Function ID for awe_fwDerefPointer().
PFID_GetWireType | Function ID for awe_fwGetWireType().
PFID_SetInstanceID | Function ID for awe_fwSetInstanceID().
PFID_Get_Flash_Erase_Time | Function ID for awe_fwGetFlashEraseTime().
PFID_Query_Flash_Erase_Complete | Function ID for awe_fwGetQueryFlashEraseComplete().
PFID_Query_Supported_Baud_Rates | Function ID for awe_fwGetBaudRates().
PFID_Set_Baud_Rate | Function ID for awe_fwSetBaudRate().
PFID_Lock_DSP | Command to forcefully corrupt DMA and lock DSP.
PFID_Reboot_Target | Function ID for reboot().
PFID_DestroyAll | Function ID for awe_fwDestroyAll().
PFID_GetFirstCore | Function ID for report first core.
PFID_GetNextCore | Function ID for report next core.
PFID_StartAudioNonSMP | Function ID for StartAudio().
PFID_GetCores | Function ID for GetCores().
PFID_FetchValues_float | Function ID for awe_fwFetchValue() as float.
PFID_GetCallFetchValues_float | Function ID for awe_GetCall() as float followed by awe_fwFetchValue().
PFID_SetValues_float | Function ID for awe_fwSetValue() as float.
PFID_SetValuesSetCall_float | Function ID for awe_fwSetValues() as float followed by awe_fwSetCall.
PFID_FetchValue_float | Function ID for awe_fwFetchValue() as float.
PFID_GetCallFetchValue_float | Function ID for awe_GetCall() as float followed by awe_fwFetchValue().
PFID_SetValue_float | Function ID for awe_fwSetValue() as float.
PFID_SetValueSetCall_float | Function ID for awe_fwSetValue() followed by awe_fwSetCall.
PFID_SetValuesPartial | Function ID for awe_fwSetValue().
PFID_SetValuesPartial_float | Function ID for awe_fwSetValue() as float.
PFID_SetCores | Function ID for GetCores().
PFID_DestroyOnly | Function ID for destroy without stop.
PFID_CheckMemory | Special for target integrity bchecks.
PFID_AWBChunk | Special for target integrity bchecks.
PFID_Comment | Generate a comment on command line.
PFID_StartAudio2 | Start audio without callback.
PFID_StopAudio2 | Stop audio without callback.
PFID_GetFirstRoute | Get the first IPC route.
PFID_GetNextRoute | Get the next IPC route.
PFID_GetValueHandle | Get value(s) by handle.
PFID_SetValueHandle | Set value(s) by handle.
PFID_GetStatusHandle | Get module status by handle.
PFID_SetStatusHandle | Set module status by handle.
PFID_GetValueHandleMask | Get value(s) by handle and mask.
PFID_SetValueHandleMask | Set value(s) by handle and mask.
PFID_GetExtendedInfo | Get extended target info.
PFID_GetCores2 | Function ID for GetCores().
PFID_CreateWireBufferPool | Function ID for awe_fwCreateWireBufferPool().
PFID_CreateWireInBufferPool | Function ID for awe_fwCreateWireInBufferPool().
