AWECoreOS 8.A.4 User's Guide
Data Structures | |
| struct | AWEOSAudioRecordNotification |
| Audio recording notification callback argument structure. More... | |
| struct | AWEOSVersionInfo |
| Versioning structure returned by aweOS_getVersion. More... | |
| struct | AWEOSConfigParameters |
| AWEOSConfigParameters. More... | |
Macros | |
| #define | TUNING_LOG_ERROR 1 |
| AWE Core OS internal tuning interface logging verbosity level: low – log only errors. | |
| #define | TUNING_LOG_INFO 2 |
| AWE Core OS internal tuning interface logging verbosity level: medium – log errors and header info from all packets sent and received. | |
| #define | TUNING_LOG_DATA 3 |
| AWE Core OS internal tuning interface logging verbosity level: high –log errors, header info and raw packet content for all packets. | |
| #define | AUDIO_RECORDING_NOTIFICATION_ERRORS (1 << 0) |
| Audio recording: Notify only on errors. | |
| #define | AUDIO_RECORDING_NOTIFICATION_XRUNS (1 << 1) |
| Audio recording: Notify only on overruns. | |
| #define | AUDIO_RECORDING_NOTIFICATION_ALL (AUDIO_RECORDING_NOTIFICATION_ERRORS | AUDIO_RECORDING_NOTIFICATION_XRUNS) |
| Audio recording: Notify on errors and overruns. | |
Typedefs | |
| typedef struct AWEOSAudioRecordNotification | AWEOSAudioRecordNotification_t |
| Audio recording notification callback argument structure. | |
| typedef void(* | recordNotificationCallbackFunction) (AWEOSAudioRecordNotification_t *) |
| Audio recording notification callback type. | |
| typedef struct AWEOSVersionInfo | AWEOSVersionInfo_t |
| Versioning structure returned by aweOS_getVersion. | |
| typedef void | AWEOSInstance |
| The AWE Core OS Instance instance type. More... | |
| typedef struct AWEOSConfigParameters | AWEOSConfigParameters |
Enumerations | |
| enum | STATUS { ERROR, INPUT_OVERRUN, OUTPUT_OVERRUN } |
| Audio recording notification status type. | |
| typedef void AWEOSInstance |
The instance itself is opaque, and it is configured with aweOS_getParamDefaults and aweOS_init. This handle will be passed to most API functions. Multi Instance integrations can utilize an array of AWEOSInstances (see the MultiInstance example app)
| typedef struct AWEOSConfigParameters AWEOSConfigParameters |
The AWE Core OS Configuration Parameter Structure
This structure will hold the config parameters for the AWE Core OS instance. A user must create one of these per AWEOSInstance, and either populate it in manually, or call the aweOS_getParamDefaults to populate it with defaults. Once the structure has been configured, it is passed in to the aweOS_init function with an AWEOSInstance, and the instance is initialized with the given configuration parameters. The heap pointers, pPacketBuffer and pReplyBuffer will be assigned to NULL when calling aweOS_getParamDefaults. If they are not overwritten by user, then memory is allocated in aweOS_init. Internally allocated heap sizes can be controlled via the heapSize configuration parameters.
1.8.18
